How Do I Root And Use Leaks
Posted 06 August 2012 - 06:42 PM
I'm new to your site. I was reading that there are leaks that can make my phone run better. I need help in rooting my phone and being able to go back to the original operating system to install the leaks. I'm very confused on how to do this. I've read a zillion postings and I'm extremely lost especially with the terminology you guys use. Sorry if I sound like a dummy. Can someone please help me and tell exactly what I need to download step by step and how to do it. i.e. do i download on my phone or do I download on the computer? Thanks in advance.
Posted 06 August 2012 - 07:55 PM
Posted 06 August 2012 - 07:56 PM
Somebody else will probably pick this up for you but if not I'll check in the morning. Good luck
Sent from my DROID RAZR using Xparent ICS Blue Tapatalk 2
- littljeff likes this
Posted 06 August 2012 - 08:02 PM
Posted 07 August 2012 - 05:31 AM
Posted 07 August 2012 - 06:50 PM
Posted 07 August 2012 - 07:09 PM
What seems to be the problem? Is the update just not taking? are you getting an error/installation aborted?ok so i've been at this most of the day. I need serious help. I was able to root my phone and get it back to original operating system 6.16.211....i tried to download and install the latest leak update and it's just not working. I can't seem to get it on my phone. Can you please tell me what I'm doing wrong???!!! i'm just on the basic screen screen i haven't even set up my phone yet. please help me...thanks.
Posted 07 August 2012 - 07:11 PM
Posted 07 August 2012 - 07:19 PM
its not an application you run on your comp... go here, it should be of great help... thanks to mattyp!i don't even know how to run the update. I can't find an application file to run...i tried to run most of the files in the download but nothing happens. no error messages just nothing. I downloaded the leak from this:
Posted 07 August 2012 - 07:20 PM
Posted 07 August 2012 - 07:21 PM
no prob at all... we all gotta start somewhere... thats what makes the android community so great, we're all here to helpahhh this is great...sorry i'm such an amateur lol thanks for all of your help.
that link was a great idea/execution by matty, don't forget to send him your thanks
Posted 07 August 2012 - 07:56 PM
Posted 14 August 2012 - 10:59 PM
The phone is already on .211 but has a corrupted radio ( Baseband version unknown ) so this is my only hope to get it working. TIA
Sent from my MB855 using Tapatalk 2
Posted 15 August 2012 - 02:14 AM
Just got a new Verizon RAZR , I already have the .211 fast boot files ( blahblah.XML.zip ) . Can I use it to flash via Matt's utility , if yes what version should I try?
Check here for the unstuck 211 utility. You can flash the radio/kernel without the need to fastboot.
- ryan8r likes this
Posted 15 August 2012 - 03:42 AM
Btw the torrent has 0 seeds. Any other link?
Edit: never mind! Got it from a user @HouseMD over chat. Will try and report back.Sent from my MB855 using Tapatalk 2
Posted 22 August 2012 - 10:33 PM
