RAZR M, XT907 4.1.2
5 replies to this topic
#1 bishop2001
bishop2001
Posted 11 February 2014 - 12:27 PM
Greetings,
can I use the DROID RAZR HD Utility 1.21 for the RAZR M, XT907 4.1.2 ?
thanks,
#2 johnthehillbilly
Posted 11 February 2014 - 12:30 PM
Depends on what you are trying to do AND what system version you are on.... (not 4.1.2).... should resemble 9.30.1 or 9.18.94 (possibly with different numbers)
  • Memnoch73 and RikRong like this
#3 Beanerman
Beanerman
  • 23 posts
  • Current Device(s):RazrM
Posted 13 February 2014 - 07:53 PM
Y don't you use Mattlgroth's "Droid RAZR M Utility 1.10 or 1.20"? And u can. Use v1.20 for 4.1.2.
#4 johnthehillbilly
Posted 13 February 2014 - 09:08 PM
Ok... to clear up the impending confusion with the utilities...... 1.10 WAS for the RAZR HD .... not the M .... and it is no longer supported(it is out dated) .... 1.20 is for the M (depending on your system version)..... and 1.21 is for the HD (also depending on what system version) .....
So please, prior to using the utility.... pay close attention to your system version AND what the highest system version the utility can be used for....... if not, you WILL run into a long list of flash failures and errors that WILL soft-brick your phone.....
#5 johnthehillbilly
Posted 14 February 2014 - 12:02 AM
Here is where all the utilities live
(for reference)
#6 Playb3yond
Playb3yond
  • 75 posts
Posted 15 February 2014 - 03:27 PM
There's also House of Moto & RSD Lite
