[Themed Keyboards]
#1 Guest_24v_*
Posted 09 August 2012 - 12:38 PM
Post #2 is for moto based roms.
Post #3 is for AOKP and CM9 based roms.
Post #4 NEW THEME KEYBOARD!
Please read each section for the instructions that apply.
- lownslow200sx, leviwg and HSD-Pilot like this
#2 Guest_24v_*
I have put together some cool keyboards, and intend to make more.
These are all flashable zips.
Your font will look different than the screens as I have changed my system font. The font will be the same as what is on your phone now.
Flash in Safestrap
Wipe Dalvik and Cache before flashing.
I'm not responsible for your phone.
These only work with Moto based roms.
These are the roms it should work on:
Dualcore
Arctic
Eclipse
SimplexRom
Black Widow 214
Links
Screenshots
- wyld, HSD-Pilot, HouseMD and 2 others like this
#3 Guest_24v_*
Flash in Safestrap
These only work with AOKP or CM9 based roms.
They also only work with stock theme. If you are running a different theme in Theme Manager these will not look like the screenshots.
Links
(courtesy of prstorero)
Screenshots
- mike_augie, HSD-Pilot, vtwinbmx and 1 other like this
#4 Guest_24v_*
Posted 09 August 2012 - 12:50 PM
This is the new Theme Keyboard.
EmericanX found the hidden settings menu in the normal keyboard and re coded it so it is in the normal settings.
This allows you to have multiple theme choices in one apk.
I will be making more versions of this so keep an eye on this thread.
Flash in Safestrap
Red Version
http://www.mediafire.com/download.php?gql8d4ducxajg4s
Blue Version
http://www.mediafire.com/download.php?9oe5792mxcrr8vf
Open the keyboard and hold down the microphone.
Click on EmericanX-24v Input Settings
Click on Debugging and Theme Settings
Click on Keyboard Theme
Choose your Theme
- HSD-Pilot, vtwinbmx and usmcamgrimm like this
Posted 11 August 2012 - 04:22 PM
Posted 11 August 2012 - 04:49 PM
#7 Guest_24v_*
Posted 11 August 2012 - 05:12 PM
Sorry, fixed it.The link for the yellow keyboard in the aokp/cm9 one is the red outline keyboard download.
#8 Guest_24v_*
Posted 12 August 2012 - 02:16 PM
- usmcamgrimm likes this
#9 Guest_24v_*
Posted 13 August 2012 - 03:24 PM
Posted 14 August 2012 - 07:25 PM
#11 Guest_24v_*
Posted 15 August 2012 - 02:42 AM
Posted 15 August 2012 - 04:26 PM
maybe a notre dame one or 49ers one and i put this on root of sd card Wipe Dalvik and Cache and only some of it came up blue the bottom half did then the upper part of the keyborad was the same just white with black letters how do i uninstall to get the stock keyboard backSure, what team you looking for?
#13 Guest_24v_*
Posted 15 August 2012 - 04:43 PM
Posted 15 August 2012 - 04:52 PM
simplex 1.2 oh boy i jacked upWhy did you put it on the root of the SD Card? The instructions say to flash it in SafeStrap. What rom are you running?
#15 Guest_24v_*
Posted 15 August 2012 - 04:57 PM
Posted 15 August 2012 - 05:44 PM
ok isnt ext sd card the same as root of sd card if not then how do i find ext sd cardIt's ok. Put it on the ext sd card, but you need to flash it like a rom. Go into SafeStrap, then wipe cache, wipe dalvik cache, and flash the zip file. Then reboot.
Posted 15 August 2012 - 05:46 PM
Posted 15 August 2012 - 05:50 PM
well i put it in the external but when i get into safe strap i can only see wipe dalvik cache as one option and i see that under advancedIt should not matter which sd card be it internal or external you place it on. As long as you can find it to flash you're golden.
Posted 15 August 2012 - 05:58 PM
if you find you need to wipe cache without data.. it should be under mounts. Format cache.
Posted 15 August 2012 - 06:36 PM
