Custom Razr Paint Job
Posted 11 August 2012 - 09:01 AM
Posted 11 August 2012 - 09:47 AM
So I'm thinking about making my OG razr into a Maxx. The only problem is that my razr is white and the Maxx is not... If I do the conversion, I'm contemplating using vinyl dye to give my razr a custom paint job (red maybe?). Any suggestions, input, criticism? Am I crazy to even think about doing this?
If you pull this off I would be interested in seeing the finished product for sure. Keep us posted!
Sent from my DROID RAZR using Xparent ICS Blue Tapatalk 2
- HouseMD likes this
Posted 11 August 2012 - 10:07 AM
Posted 11 August 2012 - 07:33 PM
Posted 12 August 2012 - 06:33 AM
Posted 12 August 2012 - 07:34 AM
Posted 12 August 2012 - 09:12 AM
I've looked at the plastic specific spray paint and the problem is that it's just a covering. With vinyl dye, it actually seeps into the plastic and dyes it. When I do paint it I'll take the two plastic parts off the phone. Does anyone know if the kevlar separates from the plastic?
I'm thinking if the plastic is'nt white the dye may go off color. Not sure about that since I'm a painter, not a dyer lol
Posted 12 August 2012 - 10:13 AM
Posted 21 August 2012 - 03:44 AM
Just paint it, it'll be much easier and it'll probably look better. If you prepare the surface properly and use a hardener it wont scratch off. You can also control how glossy you want it to be.
For reference, "dye" doesn't come in an aerosol can. I've seen several "dyes" that comes in a can....it's nothing more than a fancy paint.
Posted 21 August 2012 - 01:28 PM
Posted 21 August 2012 - 03:52 PM
Posted 24 August 2012 - 02:22 PM
Posted 24 August 2012 - 06:13 PM
Posted 24 August 2012 - 06:23 PM
Posted 27 August 2012 - 08:37 PM
I was under the impression that the back and front bezel weren't even plastic. The bezel is titanium and the back is a titanium, Kevlar combo
Mine is actually made of Unobtainium and the same material as Superman's cape.
- mal_eskrito likes this
Posted 27 August 2012 - 08:48 PM
Come on now, supermans cape is just regular cloth, the fabric just absorbs some of his properties while on him... Duh
Posted 28 August 2012 - 05:18 AM
Posted 29 August 2012 - 05:11 AM
EDIT: this stuff:
Posted 29 August 2012 - 10:05 AM
