Android Gods, I Need Your Help. "Insufficient Storage Available." Droid Razr M
7 replies to this topic
#1 AdamConnell
AdamConnell
  • 6 posts
Posted 14 February 2014 - 10:19 PM
So, today I decided to give rooting a shot. The whole .batch process went great. Followed instructions as needed. Everything was looking great, until I received an, "Insufficient Storage Available," notification from Google play. This eventually progressed into 4shared, and anywhere I can download anything. Nothing saves or installs anywhere, even though I clearly have enough space. Eventually, I factory reset the phone. Same issue. This is my only device, so help is appreciated! (Also, if you know of anywhere else to post, that'd be great, too.)
  • droidvert likes this
#2 johnthehillbilly
Posted 15 February 2014 - 01:35 AM
Typically rooting has nothing to do with storage (other than installing Superuser and busy box)...... you probably need to go into your storage and/or app settings to get a better picture of what you have installed / stored and what you can afford to delete/uninstall to free up some space.....:)
#3 AdamConnell
AdamConnell
  • 6 posts
Posted 15 February 2014 - 05:58 AM
Sadly, I did. I have 2GB free on my internal and 58GB  free on my external SD. For some reason, I can download, but not install any application out there. No matter the size. Seriously. As soon as I rooted my phone, something inside went wrong. I can't even install an unroot application... Or use any root apps, because I factory reset my phone, and now superuser is nowhere to be found. This has nothing to do with storage, but the fact that, after rooting, my phone thinks there is less than there is.
#4 Someolddude
Someolddude
  • 426 posts
Posted 15 February 2014 - 03:05 PM
Its just a glitch and it will eventually fix itself. Happened to me before and I couldn't figure it out then all of the sudden it was fine and never had another problem. You probably need to root again because you factory reset it.
#5 johnthehillbilly
Posted 15 February 2014 - 03:15 PM
Try this.... backup (to computer) your entire internal and external storages......then format both ..... then visit Sam's house of moto..... perform a FULL fxz on your phone..... then you should be back up and running properly...
  • jl90 likes this
#6 droidvert
droidvert
  • LocationDelaware
  • Current Device(s):razor m(non-dev) rooted / Tab2 7.0
Posted 16 February 2014 - 04:51 AM
mine was a replacement xt907. came with 98.16.3. has been rooted for 3 months and only this last week has it been acting the same.
but i can update only a few of my stock apps .
tried to uninstall and reinstall but some apps after uninstalling WILL NOT RE-INSTALL!!!!!
 Im trying to work on finding out WHY also.......
#7 mlzoran818
mlzoran818
  • Current Device(s):RAZR M
Posted 06 March 2014 - 05:21 PM
Did you happen to try and use either link2sd or ap manager III or something of the sort to move apps to the SD? If you did, check the settings on whichever one for the "Download new Apps to SD". Since the M doesn't recognize emulated dirves, it see's no empty space on SD. Turning the switch off put it back to the phone storage.
#8 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 07 March 2014 - 03:11 PM
Try this little app.
Insufficient storage fixer in the play store.
class='bbc_url' title='External link' rel='nofollow external'> https://play.google.com/store/apps/details?id=com.zikaeroh.insufixer
