Front Camera Randomly Gone
Posted 16 August 2012 - 10:56 AM
Picture Showing Camera App With No Front Camera Button.
Droid Razr MAXX No Root 4.0.4
How To Fix This???? Back Camera Still Woks Though.
EDIT 1: Cleared Camera Data + Cache, Problem Still Exists.
Posted 16 August 2012 - 11:34 AM
- Luckster likes this
Posted 16 August 2012 - 11:39 AM
Where do i do that, i went to Setting-AppsDid you clear data/cache for the camera?
And Cant Find "Camera"
Posted 16 August 2012 - 11:42 AM
Posted 16 August 2012 - 11:43 AM
3 TabsMake sure you're on the All tab.
DOWNLOADED | INTERNAL STORAGE | RUNNING
Checked all 3 no "Camera"
Posted 16 August 2012 - 11:45 AM
Posted 16 August 2012 - 11:49 AM
Found It, Cleared Data + Cache and Same. No Front Camera Button.The tabs scroll. It's kinda non-intuitive.
(Sorry For Being Slow)
Posted 16 August 2012 - 04:59 PM
Posted 16 August 2012 - 07:29 PM
Posted 16 August 2012 - 08:09 PM
Will DoHave someone get you the APK for the original, maybe yours got corrupted somehow. I'm not on stock so I can't pull it for you.
Posted 16 August 2012 - 08:37 PM
Sent from my MB855 using Tapatalk 2
Posted 16 August 2012 - 09:41 PM
Yes, None Of Them Show The Front Camera Option, Tested, Pixlromatic, Facebook Camera, Camera 360, Camera Zoom, And Instagram.Did you try any third party camera apps?
Posted 16 August 2012 - 09:43 PM
#15 Guest_BDH_*
Posted 17 August 2012 - 01:19 AM
Sent from my ADR6425LVW using Tapatalk 2
Posted 17 August 2012 - 07:36 AM
Link To Exactly How To Do This Please?Fastboot 211?
And Attempted A Factory Reset.... Problem Still Exists... -__-
#17 Guest_BDH_*
Posted 17 August 2012 - 08:12 AM
Just find Matt's RAZR Utility here on the forums. A fresh fastboot to 211 should hopefully fix you up.
Posted 17 August 2012 - 09:46 AM
Last Time I Used Matts RAZR Utility to go to Stock it Bricked Me... And i had to get a New Maxx..... (I Rooted, Installed Rom, When I Tried to Fastboot to stock, Utility Has Error and Hard Bricks Phone) Im Quite Scared to do it again, ive rooted plenty of phones, his utility just scares me because RSD Lite didnt fix it either.Just find Matt's RAZR Utility here on the forums. A fresh fastboot to 211 should hopefully fix you up.
#19 Guest_BDH_*
Posted 17 August 2012 - 09:51 AM
L
Get a replacement then. If neither of those will correct it then it must be a hardware issue.
