Excessive battery drain
Posted 27 February 2014 - 02:32 PM
Need Help? Send me a message
Posted 27 February 2014 - 02:59 PM
After flashing a bunch of KitKat roms i now have major battery drain. Even after going back to a rom that had great battery life. How can i tell if it is an app or my battery is going bad?
Start isolating newly installed apps or DL a battery monitoring app that will detect wake locks and/or other things that are draining your battery.
- nprevette420 likes this
Posted 27 February 2014 - 03:07 PM
Posted 27 February 2014 - 03:09 PM
Might be worth while to flash the most recent FXZ and start fresh once again.
- nprevette420 and RikRong like this
Sig by
Posted 27 February 2014 - 03:11 PM
I know i will lose root but will i lose my unlocked bootloader?
Posted 27 February 2014 - 03:20 PM
You shouldn't.
Posted 27 February 2014 - 03:24 PM
- bigjailerman likes this
Posted 27 February 2014 - 03:29 PM
there have been instances where a failed flash has caused the bootloader to show locked in fastboot, but don't let that scare you. Once you get a successful flash it shows correctly. Your qfuse is blown. No way for them to fix that. They can do something to restructure the fuses, but that is unlikely.
Sig by
Posted 27 February 2014 - 04:07 PM
Last two question. How do I root 98.30.1? And How to I get CWM recovery back on 98.30.1? Been looking and can't seem to find what I'm looking for.
Posted 27 February 2014 - 04:12 PM
Sent From My DEV X
Sig by
Posted 27 February 2014 - 04:21 PM
Being unlocked, Root you will do in recovery. Flashing recovery has a couple methods. There is a utility on dr that will do it for you and gives you the option of twrp and cwm. The key with flashing recovery is you must boot directly into recovery after flashing or it will revert back to stock on boot up
Sent From My DEV X
Are you refering to this post? [Utility]Recovery Flasher for Unlocked Bootloader Razr M V6 [1 Click] - {UPDATED 7-11-13} (Latest Recoveries)
Posted 27 February 2014 - 04:24 PM
That would be the one
Sig by
Posted 27 February 2014 - 04:28 PM
Thanks again for all your help.
Posted 27 February 2014 - 08:08 PM
Running the recovey utility without root did not work, says i dont have SU. Have to find root another way. Found this
Then I was able to install a custom recovery
Posted 27 February 2014 - 09:26 PM
Posted 28 February 2014 - 03:40 AM
Sent from my N5 on AT&T
Sig by
Posted 28 February 2014 - 08:47 AM
Just flash the recovery with fastboot.
Wasn't aware I could. I already got it though but for future reference, how do you do that?
Posted 28 February 2014 - 08:56 AM
Put the device in fastboot mode, connect to the PC. Open a cmd window on the pc and direct it to your fastboot folder. Be sure the recovery img file is in the same folder just for ease of doing. then type the following command:
fastboot flash recovery nameofrecovery.img
Where "nameofrecovery.img" is exactly the filename and extension of the recovery file you are using.
Then immediately boot into recovery. If it boots into system, it will overwrite with the stock recovery again.
Sig by
Posted 28 February 2014 - 11:22 AM
^^^^What he said.
