Posted 28 February 2014 - 08:02 AM
Posted 28 February 2014 - 09:30 AM
If you are on the XT912 Razr, don't install CWM, because you can't. You cannot use a custom recovery on a locked bootloader device. Your option is to use SafeStrap which is a sudo recovery.
Welcome aboard BTW !
- bmclean likes this
Posted 28 February 2014 - 02:24 PM
Welcome from a fellow Mainer
Posted 28 February 2014 - 07:49 PM
That is the latest safestrap for the XT912...AKA... RAZR...AKA spyder.
Download it... install it like any third party app...open the app... install recovery...reboot...when you get past the red moto logo you will see a splash screen...hit the menu button on your phone to enter recovery...then select a slot to create(boot options)...slot one works for most everything...you can make a back up of stock at this point if you'd like (probably should)... after that activate the slot you created...NOT the stock slot!...and follow the instructions given from whichever ROM you have downloaded on your phone.
Happy flashing!! \m/
Posted 03 March 2014 - 08:23 AM
Thanks Berzerk! I did as suggested just now. Not sure if I hit the right "menu" button. It is kind of stuck on a screen that is all black except the bottom three buttons and the "updating partition details...." words above it. I didn't notice anything that said menu, so I hit the non-descript button in the middle at the bottom. I'll wait awhile longer and then force a restart. Then I'll go read more about Safestrap 3.65.
Posted 03 March 2014 - 08:24 AM
Thanks. Didn't play football for UMaine did you?
Posted 03 March 2014 - 08:33 AM
Thanks. It has been fun learning about these options and making things work. I thought about installing CWM again just to recover the backups I made, but I think I'll just skip that. I'm back up and running, rooted again, Safestrap 3.65. After flashing the stock rom with Razr Blade, I noticed I'm not getting any sound using certain apps. Pandora and Youtube to be exact. Ever heard of this happening? Maybe a different Rom will restore sound for these apps.
#8 Guest_Dalvik_Cache_*
Posted 03 March 2014 - 09:52 AM
writing apps for mobile devices as well as rooting, custom roms and darker subjects like this.
Hi Bruce,
Welcome to the site! Secondly, LOL at "darker subjects". I can't decide if I automatically fall back us hacker types, or something that should be taught at Hogwarts in "Defense of the Dark Arts" course!
- jl90 and bmclean like this
