My Droid Razr Thats On Ics 4.04 Won't Root, What I'm I Doing Wrong?
Posted 20 August 2012 - 03:03 PM
It just sits there,
Any ideas? I'm following his instructions exactly and I've tried two separate computers.
Posted 20 August 2012 - 03:06 PM
Posted 20 August 2012 - 03:14 PM
Posted 20 August 2012 - 04:51 PM
Posted 20 August 2012 - 05:08 PM
Data wipe? Please clarify. Like factory reset?
Yes but only do that if nothing else works.
Posted 15 January 2013 - 09:35 AM
usb debugging enabled
connecting MTP
when I run the batch file, I get the message daemon is starting.. then nothing.
I believe my issue has something to do with the moto drivers, but I'm not sure. I've installed "Motorola_End_User_Driver_Installation_5.2.0_32bit.msi" on a Vista machine and an XP machine with no difference.
please help!
thanks
Posted 15 January 2013 - 10:39 AM
Hey guys. New member here. Resurrecting this old thread to ask your help rooting my Razr [xt912] Android 4.04
connecting MTP
please help!
thanks
ISSUE SOLVED... I NEEDED THE 5.9 MOTOROLA DRIVERS. ROOT WORKED.
Posted 15 January 2013 - 11:51 AM
great
