You will need to stick with blur roms as you are stuck with the stock kernel.
Help with device is locked erro
#21
Posted 06 March 2014 - 01:45 PM
#22
Posted 06 March 2014 - 03:01 PM
#23
Posted 06 March 2014 - 03:08 PM
Be sure to create a slot. Don't flash it over your stock slot.
#24
Posted 06 March 2014 - 03:42 PM
Look up that blog I referred to earlier. It talks about everything you need to do to set up SafeStrap.
Blur roms? So one I find them look like 500mb or so. I just do what copy to SD card and use Strat to install it in a slot?
RikRong, on 06 Mar 2014 - 1:26 PM, said:
The root method posted in that thread is incorrect. However, the SS part is accurate. I prefer to go straight to Hash's blog and follow the instructions there. Google "how to safestrap" and the first result should be a link to Hash's blog.
#25
Posted 06 March 2014 - 04:08 PM
#26
Posted 06 March 2014 - 04:16 PM
Safe strap is up but when I make a slot it create it on phone not SD card
Yeah, it's going to create it on the phone. That's the one thing about SS, it eats up internal memory. When I used it, I formatted the slot for 1gb and there was more than enough space left for my apps.
#28
Posted 06 March 2014 - 04:27 PM
ahh ok so create it then at 1gb then download the zip rom to ext then run install to create the rom from the zip to the slot?
#29
Posted 06 March 2014 - 04:28 PM
again thannk you all for the help as you can tell im trying this for first time and all
#30
Posted 06 March 2014 - 04:31 PM
Save the ROM .zip where ever is convenient for you, then create the ROM slot, activate the ROM slot, and flash the ROM in that slot. When you reboot the phone, it will now boot into that slot. Don't flash over your stock slot.
#31
Posted 06 March 2014 - 04:32 PM
getting deadcalm from
to test and see.
so boot to recovery creat a 1gb slot copy the zip to ext sd? and then run install to place it in that slot?
#32
Posted 06 March 2014 - 04:33 PM
how do you get it to pull the zip from ext to slot or just run the install and go from there?
#33
Posted 06 March 2014 - 04:37 PM
When you go to install, you will get a type of file explorer that will allow you to choose the file you want to flash.
#34
Posted 06 March 2014 - 04:41 PM
all cool ty finishing the download now
#35
Posted 06 March 2014 - 05:21 PM
dang it flash failed at end did install then ext then selected zip. i get
finding update package
opening update
installing update for a few mineuts then
assert failed: write_raw_image("/tmp/boot.img", "boot"e:error in /external_sd/roms/deadcalm_v1.4.zip
(status7)
#36
Posted 06 March 2014 - 05:27 PM
ok so weird got those eror messages but on reboot it is loading the new one? ok well that is weird but it looks like it worked
