Recently Rooted My Razr. Stuck On Red "m" Please Help!
23 replies to this topic
#1 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 01:08 PM
Hello. I recently rooted my droid razr maxx. When I shut it off, It comes to the red motorola logo and stops there. I don't know what to do. Also, i think the battery is dead. when i plug it into the charger the "M" pops up and it stays until i unplug it. Please help. I don't know what os version is on it and I'm Freaking out!!!
--Kevin
#2 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
  • Google+:bstrong9211
  • LocationNorth Carolina
Posted 26 August 2012 - 01:29 PM
Hold down power and volumn- buttons to reset the phone, when the screen turns off hold power and volumn+ buttons. Select recovery from the menu that comes up then when the DROID guy pops up hit both volume buttons and then select data wipe/factory reset
Invictus Maneo!
#3 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 03:22 PM
Thank you for the quick reply. My first try at reset was was at a powered off state. Nothing happened. Then I connected it to my non-usb wall charger. Immediatly, the "M" splash screen loads. I held down VOLUME UP & VOLUME DOWN for five seconds. The splash screen remained. I then held them down for ten seconds with the same result. I unplugged the charger at that point and the screen zapped to black (Like a tube TV does if you pull the plug).
I attemted the same action with the original usb charger plugged into the wall. A white light quickly flashed once. The "M" splash screen loaded with identical results to the non-usb charger.
I connected the razr to my computer with the original usb cable. The white light came on and stayed on. At reset, the white remained, and nothing loaded on the display.
I then, out of despiration and a bit of curiosity, pushed and held VOLUME UP, VOLUME DOWN & POWER for about 10 seconds. A the white light went out. and a boot menu loaded. That's where I am now. I will appriciate any help you can give me.
Thank you so much!
--Kevin
In Inventory:
1976 Chevrolet Nova Hatchback
Droid RAZR MAXX - Bricked Edition
UPDATE: The screen went blank from the boot menu after about five minutes. It appeared that the battery had dies. I connected the non-usb charger and the "M" splash screen loaded. That's where I am now.
Edited by artanisman, 26 August 2012 - 03:31 PM.
#4 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
Posted 26 August 2012 - 03:31 PM
Do you see recovery in the menu?
Invictus Maneo!
#5 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
Posted 26 August 2012 - 03:36 PM
Okay hold down just the volume down button and power button it may take 15 seconds <br /><br />Sent from my DROID RAZR using Tapatalk 2
Invictus Maneo!
#6 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 03:39 PM
Yes that was an option.
Options were as follows:
Normal Powerup
Recovery
AP Fastboot
BP SPF Flash
BP Only
BPWW Diag & Boot AP
BP Tools
#7 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
Posted 26 August 2012 - 03:42 PM
Okay, hold down the power and volume down buttons until your screen goes off. Then hold all buttons and it should get you back to that menu
Invictus Maneo!
#8 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 03:46 PM
From the boot menu I pushed and held the VOLUME UP & DOWN for fifteen seconds. The screen shut off. It is still connected to the computer.
#9 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
Posted 26 August 2012 - 03:51 PM
Download this on your computer.
[Windows]-For-Verizon-Droid-Razr/maxx-Only!
Unzip it and run it.
Try booting your phone again, you should get stuck again. Hold power and volume down, then all buttons when you get to that menu again use volume down to highlight "ap fastboot" and volume up to select it.
Invictus Maneo!
#10 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 03:54 PM
Got it.
#11 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
Posted 26 August 2012 - 03:58 PM
Got it.
Use selection 1 on the 1.81 utility
Invictus Maneo!
#12 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 04:02 PM
The phone would not power up. No white light. I tried twice. I unplugged it from the computer and connected the non-usb charger. The splash screen loaded.
#13 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
Posted 26 August 2012 - 04:05 PM
Follow the instructions in this thread to try to charge your battery
Invictus Maneo!
#14 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 04:08 PM
It appears as though the battery is dead. It has been connected to the computer for at least two hours. Past experience leans me to percive power is recieved to the motherboard in one way or another. Though I recognize that is not the case in any post in the droidrzr forum.
#15 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 04:14 PM
I unplugged the phone from the non-usb charger and it shut off. I held down VOLUME UP & DOWN. The splash screen loaded and has remained for about five minutes.
#16 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 04:32 PM
I connected to the computer about five minutes ago. The white light came on and stayed on for all five minutes. I attempted to enter the boot menu. It worked. I selected AP Fastboot and a low charge messege loaded. At that point it lost power.
#17 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 26 August 2012 - 04:44 PM
Did you try plugging device to a wall charger while it is powered down?
Sent from my Simplified Droid Razr
#18 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 04:53 PM
Thank you for your response. I have connected the wall charger while power off. The "M" splash screen loads and stays indefinetly.
#19 artanisman
artanisman
  • 14 posts
Posted 26 August 2012 - 05:22 PM
Update: Ive had the phone connected to the computer for about an hour. The white light was on the whole time. I sucessfully entered the boot menu. I then entered ap fast boot.
Battery Low Cannot Program.
Transfer mode:
USB Connected
#20 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
Posted 26 August 2012 - 05:36 PM
Use the boot method in this link to try charging <br />Sent from my DROID RAZR using Tapatalk 2
Invictus Maneo!
