Supersu Help
t1.8matt
, Aug 27 2012 04:08 PM
10 replies to this topic
Posted 27 August 2012 - 04:08 PM
I decided to try out SuperSU instead of superuser, and I need to k ow how to delete superuser out of my system. I was only able to go into manage apps and disable it from there, but I know it's still on my system. How and where do I get rid of it? I tried from system/app but it wouldn't let me, and it was set for r/w.
Sent from my liquid smooth Bionic
Posted 27 August 2012 - 04:59 PM
Check out this thread at XDA it has a flashable zip and also might be able to get help there from the guy who created it
Sent from my DROID BIONIC using Xparent SkyBlue Tapatalk 2
Posted 27 August 2012 - 05:16 PM
That's where I got it from. I couldn't find anything as to deleting superuser
Posted 27 August 2012 - 05:34 PM
Flash the zip it replaces the old superuser with the superSU it will still say superuser in the app folder but trust me its the superSU I know because i flashed it just a few minutes ago
Posted 27 August 2012 - 05:50 PM
Yeah, but I had both su apps installed until I disabled superuser then it disappeared.
Posted 27 August 2012 - 06:06 PM
I don't know why that happened all i can tell u is go to the xda link above and ask your question there sorry i couldn't help u but maybe u will have luck there
Posted 27 August 2012 - 07:04 PM
It's cool, thanks for the info though
Posted 27 August 2012 - 07:54 PM
I use supersu pro. To get rid of super user apk remove it from system/apps using a root file explorer of your choice. Just make sure supersu has taken over first.
Posted 27 August 2012 - 08:25 PM
It's all good, I guess it just needed a reboot after I disabled it, because now it's saying I can just install it from the play store instead of just enabling it. Thanks.
Posted 29 August 2012 - 03:58 PM
What are the real benefits of using SuperSU over Superuser?
Posted 29 August 2012 - 04:01 PM
Haven't really noticed a benifit other than not having to worry about outdated binaries. I have it on my tf101 running EOS 3 so I figured I'd give it a try on the bionic.
