Hey Guys,
I was messing around with the latest cm10 build and one thing i noticed is the keyboard sounds were much nicer than the typewriter ticks that ics keyboards have. That's why i made this simple mod to change the keyboard sounds in ANY ROM (GB, ICS, JB, Whatever )
Basically this mod works by replacing the keyboard sound files in /system/media/audio/ui. You can replace those sounds with whatever you want and as long as you fix permissions and reboot it will work I still made this zip so you don't have to worry about deleting files or permissions
LINK TO FLASHABLE ZIP -
LINKS TO AUDIO FILES (NOT NEEDED IF FLASHING ABOVE ZIP)
KeypressDelete = http://dev.crackflasher.com/alexabraham/JBSounds/KeypressDelete.ogg
KeypressReturn =
KeypressSpacebar =
KeypressStandard =
Just download those, replace the files in /system/media/audio/ui and change permissions to match the permissions of the other files in there
[Mod] Cm10 Keyboard Sounds (Flashable Zip & Manual) (Any Device)
Alex.Abraham
, Aug 27 2012 05:14 PM
cm10 jb jellybean keyboard sounds
4 replies to this topic
Posted 27 August 2012 - 05:14 PM
- mugsy77, mattlgroff and wabmorgan like this
Posted 30 August 2012 - 10:58 PM
Really cool. Sounds like tapping on glass. (At least to me.)
Posted 03 September 2012 - 12:07 PM
Ya i really like it also (honestly i think it sounds iphone-like )
Posted 19 October 2012 - 07:12 PM
Can these be reupped?
Posted 20 October 2012 - 02:36 PM
Try this link
Also tagged with one or more of these keywords: cm10, jb, jellybean, keyboard, sounds
