Droid will not turn on. Plug in charger and sometimes just get a flash of the white LED and blank screen even after an hour or so. Tried a different charger and same thing or no white LED at all. Using a 5V 800ma micro USB charger. Unit depleted battery the night before this happened. Tried different combinations of power and up/dn buttons to turn on to no avail. The unit is almost 2 years old. Could it be the battery? Are these batteries servicable? Any ideas on how to kick it on?
Posted 25 March 2014 - 03:09 PM
Posted 25 March 2014 - 03:10 PM
Sent From My DEV X
Posted 26 March 2014 - 04:57 AM
If the only thing that happened is the battery was depleted, you can try removing the SD card. I use to have a phone that wouldn't charge if the battery was completely depleted and the SD card was in. I know it sounds weird but it was the only thing that worked. The phone could be plugged in all day long and wouldn't take a charge but as soon as the SD card was out it would take a charge like a champ.
