Process Com.android.phone Has Stopped
Posted 30 August 2012 - 09:35 AM
What can I do??
Posted 30 August 2012 - 09:53 AM
Posted 30 August 2012 - 10:16 AM
Posted 30 August 2012 - 11:57 AM
Posted 30 August 2012 - 12:11 PM
What are you on. If .905 you could flash a modified fxz to restore the system with out wiping data or if you are on an ICS leak use HOB to go from the same to the same leak while keeping data.
FXZ is for taking the phone back to stock per say but being he is on the safe side using SS, or so it seems, FXZ'ng would not be a good thing for him to choose since all he has to do is wipe data and reload the ROM he chooses to fix his problem unless he has a nandroid he can just restore.
- dfib likes this
Posted 30 August 2012 - 12:47 PM
Thanks. I have my head up my arse lately, skipped right over the big SS part.
Posted 30 August 2012 - 01:22 PM
I understand completely. i am fighting with a virus on my computer that hit me last night.
Posted 31 August 2012 - 04:35 AM
- twinkyz1979 likes this
