Deodexed 6.7.244
Posted 10 September 2012 - 02:34 PM
Steps for installation
1. Download the file from a link above
2. Place on your phones external sdcard
3. Boot into CWM recovery using BootStrap
4. Select intall ZIP from sdcard
5. Choose ZIP from sdcard
6. Locate the Deodexed ZIP and select it
7. When installation is complete choose reboot system now
8. Once you get by the BootAnimation you will see android is upgrading applications
9. Once that is done you will then be able to enjoy your newly deodexed 6.7.244
I am not responsible if you do something wrong and mess up your phone.
- johnlgalt and T3T3droid like this
Posted 10 September 2012 - 03:22 PM
Thanx
- twinkyz1979 and Thepatriotvirus like this
Posted 10 September 2012 - 07:49 PM
Posted 10 September 2012 - 07:52 PM
- twinkyz1979 likes this
Posted 10 September 2012 - 08:08 PM
Thanx downloading now
Posted 11 September 2012 - 10:55 AM
**EDIT**
I flashed this using bootstrap and now my phone does not work at all.. For example.. phone FC, text message FC, process com.android.phone has stopped working.. HELP?
Posted 11 September 2012 - 06:16 PM
Tap'n from my Nexus 7 AOKP
Posted 11 September 2012 - 07:49 PM
Why do people flash stock deodexed ROMs? It really confuses me. A deodexed stock rom is nothing more than a blank canvas for themesr/modders. Flashing one just for the sake of flashing something other than stock is kinda...well...useless. I've heard the hocus pocus about them "feeling faster, smoother, snappier, etc." I call bs. It's placebo effect. Deodexed ROMs are nothing more than a nice starting place to mod and theme. They aren't really "ROMs" using the typical users definition of what a rom" is.
I usually flash just so i can add my own flavor to it but never really have the time to do a complete theme
- johnlgalt likes this
Posted 11 September 2012 - 08:01 PM
Going to give this a go! Thanks
**EDIT**
Not sure really shouldn't have any of those problems (with the downloads from my new links) i would re-download and try install again may have been bad the first time. You are the first one i have seen having any problems.
Posted 11 September 2012 - 08:03 PM
I myself just like to add in my own twist on things here and there nothing more than that really.
- johnlgalt and bhp117 like this
Posted 12 September 2012 - 03:43 PM
There is one reason. Another is that some people make their own themes but do not release them to the public for whatever reason (such as NSFW themes).
I have several hundred pics (out of which at least 30% are NSFW) that I had originally sized to fit the D1 screen dimensions exactly (either length, width, or both if it was the correct aspect ratio) that I have posted up at my Picasaweb account. I could easily make a theme called the Joe Francis theme, but you bet your life I would not be able to post pics on most family-friendly sites. DF even asked me to remove my links in my signature (8 months after I put them up there with clear NSFW warning labels).
- twinkyz1979 and bhp117 like this
Posted 16 September 2012 - 09:08 PM
also, many mods / scripts that aren't device specific assume that you have a deodexed system (like v6, beats control, etc). flashing into an odex system either won't persist or could totally screw stuff up lol.
