[Recommendation] Notification Toggle
Posted 13 September 2012 - 09:42 AM
Screenshot from the 09/12/12 update to Notification toggle from the play store. Now with Moto 1% battery indicator for the ongoing notification placeholder.!!
Get your 1% and set up your toggles exactly how you want ..
2 color choices on the 1%.
On the toggles, I like how you can adjust the screen timeout or keep screen on from the same toggle.
- imdaman99 likes this
Posted 13 September 2012 - 09:45 AM
Posted 13 September 2012 - 11:50 AM
Posted 13 September 2012 - 01:24 PM
For direct GPS switching yes. And I do currently have it set as a system app(used TiBu).But I actually like the idea of indirect switching, being a shortcut to Location settings- that way you could turn off all 3 location services if preferred.Does it require installing as system
Posted 13 September 2012 - 01:31 PM
I still would prefer it on a custom ROM too instead of pre fab toggles built in that cant be changed or themed by the end user so easily. Tons of options with NT! Shortcuts to apps, any kind of toggle, multiple themes, responsive dev.That is a nice update for anyone running stock.
Posted 13 September 2012 - 03:33 PM
Totally agreed. These ROM notification toggles do absolutely nothing for me. Like you said, it should be up to the end user to configure his own toggles. I use Power Toggles, and the flash light toggle it's the most useful thing to me.
Posted 13 September 2012 - 04:28 PM
Tap'n from my Nexus 7 AOKP
Posted 13 September 2012 - 04:30 PM
Maybe I'm confusing this app with a different notification toggles app, but yo can pick and choose which toggles you want, what order you want them in and there's a boat load of icon packs you can download and theme this app with. I must be thinking if a different app called "Notification Toggles"
Edit: nope, I clicked the link, I am talking about the right app. This app has a lot more features than you're all giving it credit for.
Posted 13 September 2012 - 04:44 PM
Posted 13 September 2012 - 04:59 PM
We have nothing bad to say about Notification Toggles. It's a good app. We're saying that we wish the built-in ROM toggles have those same configuration opportunities.
Posted 13 September 2012 - 06:34 PM
Posted 13 September 2012 - 06:48 PM
This was basically my original point. I was originally using the transparent icon to keep the status bar cleaner looking, but wanted easy 1% so would use Battery Circle for that. USUALLY that transparent icon was great but sometimes it would end up between other icons just causing a space. With this latest update including the Moto 1% for an icon-Well I just get everything I want with just one app and no funny business."Notification Toggle" by J4velin is excellent. He has several different icons to choose from too.
Posted 06 November 2012 - 07:16 AM
directly call phone numbers
Allows the app to call phone numbers without your intervention. Malicious apps may cause unexpected calls on your phone bill. Note that this doesn't allow the app to call emergency numbers.
My phone: Motorola Razr GSM XT910 "Maxxed" - Running stock JB 4.1.2 @ Lightning Launcher + Zooper Widgets PRO
Posted 17 November 2012 - 01:18 PM
See sreenshot of PlayStore explanation:Why does it require this permission ?
94.68KB 10 downloads
So that permission is to direct dial a contact from a toggle.
