Screen Rotation Issue?
Posted 13 January 2012 - 08:50 AM
Scrren gets stuck in landscape mode quite often. Usually haapens when I am in landscape and the phone either times out, or I press the power button to turn off the screen. So when you wake the phone back up, it is stuck in LScape and wont switch back unless you toggle the hell out of some buttons (home, or move phone back and forth)
Anyone else confirm or deny this?
Posted 13 January 2012 - 09:37 AM
Posted 13 January 2012 - 09:43 AM
when you mean lag...youre talking about getting stuck in landscape right?Unfortunately this is a problem. Must be I'm on 3 replacements and all three do it.. who ever says theirs don't LIE! the one in the store even lags... I can tell you that Razrx. V 1.1 does not lag.. least not yet
Mine did it in razrx 1.1 too
Posted 13 January 2012 - 12:41 PM
It may be a hardware error. You can try going to Settings and turning off the landscape option.when you mean lag...youre talking about getting stuck in landscape right?
Posted 13 January 2012 - 12:54 PM
you mean auto rotation? In display settings?It may be a hardware error. You can try going to Settings and turning off the landscape option.
I do want my phone to work in landscape...
Posted 13 January 2012 - 01:04 PM
Well thats what I meant, but yea. I would have checked settings myself but I was RSD Liteing my phone. I'd probably get a replacement Razr. Sounds like the hardware piece that tells which way its facing is broken.you mean auto rotation? In display settings?
Posted 13 January 2012 - 01:21 PM
So your razr doesn't do that I'm assuming..
Posted 13 January 2012 - 01:27 PM
Don't lie matt hahaha they all get stuck at least once. Lol
Posted 13 January 2012 - 01:30 PM
so you get no lag on 1.1?Don't lie matt hahaha they all get stuck at least once. Lol
Also is there a way yet to keep radio from 173 on 748? I'm thinking eastern won't mesh with 173 & 2.3.6
Posted 13 January 2012 - 01:35 PM
Razrx is very smooth, I've notices my landscape lag has dramatically improved. Its also all in how your phone is themed. Some launchers just can't handle the awsomeness of the Razr
Posted 13 January 2012 - 01:43 PM
I get lag on stock home too. But not as much<br />Razrx is very smooth, I've notices my landscape lag has dramatically improved. Its also all in how your phone is themed. Some launchers just can't handle the awsomeness of the Razr<br /><br />Sent from my DROID RAZR using Tapatalk
What launcher works well?
Posted 13 January 2012 - 02:12 PM
Posted 13 January 2012 - 04:20 PM
I figured out the culprit for my screenlag/rotation issue.
I was susing a program used on all my previous phones called No Lock, it keeps us from having to unlock the phone all the time.
Anyway it was this that was causing the lag.
Does anyone know of a program similar that might work?
Posted 16 January 2012 - 04:38 PM
Posted 08 February 2012 - 06:44 AM
UPDATE:
How did you determine that "No Lock" was the culprit?
Posted 08 February 2012 - 12:07 PM
trial and errorThanks dude....great video. Just wanted everyone to know this is my first time rooting a droid phone. So far so good...no issues. Just now waiting on a Valid Flash clockworkmod recovery mod,
Posted 08 February 2012 - 12:47 PM
trial and error
I've had the same problem and also had "no lock" on the phone. I uninstalled "no lock" but the auto rotation sometimes fails to work.
Are you saying that since you removed no lock, you've had no problems whatsoever with the auto rotation feature?
