Battery bleed
Posted 30 April 2014 - 06:41 AM
Posted 30 April 2014 - 07:42 AM
Have you gone and checked the battery stats to see what might be eating up your battery? Are you in an area that has a weak 4g signal?
These are all different things that could cause an issue. That, or your battery is going bad or there is a hardware malfunction.
As for the slow and laggy performance, have you cleared dalvik and cache? That sometimes helps.
Also, do you have a LOT of apps installed? What apps do you have installed? How much space do you have on your system and internal storage? If you have too many apps on your phone that eat up internal memory space, it can cause the phone to lag. That, or you have a misbehaving app.
Again, do the battery stat check and see what it says. You just might find that you have an app that isn't behaving right and that could be the culprit of your battery life being bad and performance of the phone being laggy.
Posted 30 April 2014 - 09:03 AM
