Hi everyone here, i search many many post, and no one with the same situation with me, so i had to ask here
I'm on Official MIUI 2.9.14 ICS build, and i wanna go back to stock ICS due to Lapdock compatibility. And this is the scenario.
I'm on Asia Retail 2.3.6 before that, flash follow MIUI Official guide, flash a EU Retail via RSD lite as following,
SPDREM_U_01.6.5.1-167_SPU-15-M2-3_SIGNEuropeAustraliaEMEA_USASPDRRTGB_HWp2b_Servic e1FF_fastboot.xml
then razr_4.04_europe_ota, then MIUI
so, back to what just happened, i try to go back to stock via RSD Lite again, since i flash a EU Retail before, and been told that it is impossible to back to GB, should back to ICS, then i assumed that i should flash back
SPDREM_U_01.6.5.1-167_SPU-15-M2-3_SIGNEuropeAustraliaEMEA_USASPDRRTGB_HWp2b_Servic e1FF_fastboot.xml,
so after decompressed, and flash, it got me back FLASH FAILURE.... YAY.... Fastboot Loop.... Phone LOCKED, Status 0
then i found the way to charge my battery, phewww. but..... i found one more thing, in RSD Lite, while i connect my phone in fastboot mode,
My phone is detected, status Conected, BUT.... in the above ESN, Technology, Software Version, Flex Version, DRM Version, Bootloader Version, Phone Type... ALL APPEARED as N/A
Now a charging RAZR, fastboot loop, i'm downloading Asia Retail 2.3.6, Downloading RAZR Utility(Seems like no use to me?)
Any suggestion what should i do?
RSD Lite, fastboot mode, flash Asia Retail 2.3.6?
or
RSD Lite, fastboot mode, flash Eternity Project Final ICS Eu Retail?
A very very thanks in advance, and please forgive my poor grammar.
Update : I found that i can go to original recovery (dunno what can do here), and on Boot mode selection(Volume UP+DOWN+Power), i can scroll down to BP HW Diag & Boot AP, then i can boot up my original MIUI, but it cant connect to pc using USB nor Charging on wall plug, USB not functioning, kinda weird, then i reboot again (Volume UP+DOWN+Power), this time enter BP Tools, yay... this boot up the MIUI too, but with functioning USB DATA+Charge... but everytime i reboot the RAZR, it ends up stuck at AP Fastboot Bootloop, i had to use the method (Volume UP+DOWN+Power) to boot up correctly, and if i do the (Volume UP+DOWN+Power), i wait for 10-15 secs, it will also automaticlly boot to MIUI with functioning USB.
Now what? LMAO..... what should i do? any expert here can tell me what to do? How to get back to stock ICS? using bootstrap recovery? using original recovery? using RSD Lite?
Miui Ics Revert To Stock Get Semi-Bricked. Help!
Babyken
, Sep 18 2012 07:22 PM
No replies to this topic
