Deleted Android System. . . No Backup
Posted 27 September 2012 - 01:48 PM
Posted 27 September 2012 - 02:18 PM
While I was switching to a ROM, there was a step where I had to delete android system. I had backed up prior, so there weren't any worries. Unfortunately, I didn't save the .zip rom file in my SD card properly, so I was stuck in bootstrap. I pressed reboot device. With no android system. So now I'm stuck with a useless phone. Anyway of fixing my phone? I'm a noob at this. :|
If you can get to AP fastboot use matts 1.81 utility to flash 211.... assuming you were already on ICS
Posted 27 September 2012 - 02:24 PM
Did you have bootstrap from boot installed? As in on boot does it go to bootstrap first? There use to be a trick on the DX as well... when powered completely off plugging into a wall charger would force into bootstrap.
If you can not get into bootstrap flashing the restore as mentioned is your best option. You could try to simply flash the stock system.img but you will probably need to wipe data/cache.
Posted 27 September 2012 - 02:33 PM
Posted 27 September 2012 - 03:13 PM
Posted 27 September 2012 - 06:16 PM
I've also been trying to get back to bootstrap since I have a backup saved, but I'm unable to. I didn't download boot to bootstrap.
Posted 28 September 2012 - 10:43 AM
I was using stock ICS rooted. I know what I did wrong, but I still don't know how to fix it. I've been messing around with Odin with no avail.
...wait this is the RAZR help section, you mentioned "Odin" do you have a RAZR or a Samsung phone?
Posted 28 September 2012 - 03:13 PM
I'm downloading DroidRazrUtility 1.8 right now, which will take some time since my home internet is pretty slow. I'll have an update on whether or not I fixed my phone. Thanks for all the help! Really appreciate it!
Posted 28 September 2012 - 03:17 PM
I have a RAZR, and now that you mentioned it, it just hit me that it would make sense ODIN is only for Samsung phones.
Just use RSD lite and search for the razr ICS fast boot file. It will return your phone to a factory unrooted image.
Posted 28 September 2012 - 04:20 PM
Posted 28 September 2012 - 05:11 PM
Posted 28 September 2012 - 05:25 PM
I downloaded RSD Lite, got into AP Fastboot; now, what filename am I supposed to select?
Assuming you have a VZW CDMA XT912 Razr (not gsm or some Samsung device) you need to flash this file
In RSD lite from ap fastboot mode on your phone. Btw, don't unzip this file. Just use it in RSD as is.
Sent from my peanut butter and jelly sandwich
Posted 29 September 2012 - 03:39 AM
Posted 29 September 2012 - 03:50 AM
Posted 29 September 2012 - 06:28 AM
I found the ways to do it, but I'm really unsure of whether or not I want to break apart my phone.
Factory programming cable from TBH. Someone mentioned another cable that may be more available but I forget where I saw it.
EDIT: Just checked... TBH cable is out of stock atm.
Posted 29 September 2012 - 06:47 AM
Or this very generous offer.
Posted 30 September 2012 - 06:55 AM
Posted 30 September 2012 - 10:52 AM
I purchased a Factory Adapter from Team Black Hat; when it arrives, I'll update on whether or not I fixed my problem!
Yeah would like to know how it turned out.
Posted 03 October 2012 - 09:21 AM
in the chat room I got my phone to work again! Of course, everyone who posted on this thread helped me as well! Thank you all!
