Overseas with a Droid Razr M
Best Answer johnthehillbilly , 22 May 2014 - 02:55 AM
Typically, on stock, you should have no troubles using an overseas "local" sim...... It varies on a custom ROM tho.... Go to the full post
3 replies to this topic
#1 arc1880
arc1880
  • 74 posts
  • Current Device(s):RAZR M
Posted 21 May 2014 - 06:52 PM
In about two weeks I'm leaving for the Philippines and I was wondering if I can use my Droid Razr M there with a GSM sim card. I'm currently unlocked and rooted running a 4.2.2 ROM. Any assistance would be great.
#2 johnthehillbilly
Posted 22 May 2014 - 02:55 AM   Best Answer
  • bigjailerman likes this
#3 arc1880
arc1880
  • 74 posts
Posted 22 May 2014 - 10:11 AM
Oh so it does vary on custom roms? I'm currently in the U.S. and purchased a Globe sim for my phone. My brother did the same for his iPhone 5S and his works. I guess I'll have to go to stock for a bit to see if it works. I'm currently running the 4.2.2 of CM.
#4 johnthehillbilly
Posted 22 May 2014 - 10:22 AM
Some users have reported full functionality (to the extent possible) while on GSM networks abroad, while others have had to revert to stock to be able to "run with it"........
