Hi all
I'm newbie on this forum and not too sure is it a right place for it. I've got huge problem with my Moto. I've already posted it on xda, but as far as now nobody came back with any solution, so i'll try to give it go here.
Posted 22 May 2014 - 01:12 AM
Hi all
Posted 22 May 2014 - 04:19 AM
The fact that you've just randomly started flashing FXZ's without knowing what you're flashing means there's not much I can do for you. You need to find the appropriate, latest version, FXZ for your phone and flash it.
Posted 22 May 2014 - 05:16 AM
I bought that phone as faulty software issue. Normally it will stuck on M logo, but if i press Power and Volume down button it goes to AP Fastboot, also i don't know to much about android software, how to unbricked ot whatsoever
Posted 22 May 2014 - 05:18 AM
That's great and all, but, if you flash the wrong FXZ, you brick it as you've already discovered with the errors in your pictures. You need to find the LATEST FXZ for your phone and flash it. If it doesn't fix it, then there's not a lot that can be done.
Posted 22 May 2014 - 05:23 AM
Could U tell me what FXZ means and where I have to looking for it?
Posted 22 May 2014 - 05:27 AM
Posted 22 May 2014 - 05:34 AM
FXZ is what the firmware you flash in rsd is called. You need to find the appropriate one for your device, location and latest system version. You should be able to locate it on this page -
Sent from my S-Offed One M8
I've downloaded few of them (Retail Europe), but can't install them through AP Fastbook as it seems like Getvar blocked it.
Posted 22 May 2014 - 05:46 AM
Download and install (READ FULLY BEFORE INSTALLING):
use this FXZ that you already downloaded: CFC_9.8.2I-50_SMI-26_S7_USASMIJBRTEU.xml
Extract this file into the FXZ_xt890 folder:
Run the HouseOfMoto.bat file, choose fastboot flash mode. Follow the instructions.
Posted 22 May 2014 - 05:57 AM
Nvm
Posted 22 May 2014 - 05:58 AM
Should i uninstall Motorola Device Manager (as i've installed before) with USB drivers and go for which You linked in Your post or kept that one which already have installed?
Posted 22 May 2014 - 05:59 AM
Install the latest.
Posted 22 May 2014 - 06:02 AM
Install the latest.
Ok. will do, and keep U posted. Thanks for that
Btw. As far as i understand i have to copy all files from CFC_9.8.2I-50_SMI-26_S7_USASMIJBRTEU.xml
into FXZ_xt926 folder, but it won't be .img file as there aren't any .img files. Is that correct?
Posted 22 May 2014 - 06:22 AM
When i starting HouseOfMoto-ScriptGenerator it didn't show me any files (no .img)?
Posted 22 May 2014 - 06:24 AM
You need to extract the ENTIRE FXZ into the FXZ_xt890 directory. The instructions on this are very clear.
Posted 22 May 2014 - 09:06 AM
Still don' know how to do it, i mean how to change it in .img . Can You show me step by step how to?
Only such a files comes in that folder. (pict. 8)
Posted 22 May 2014 - 09:10 AM
I don't do "step by step" when I've laid it out very clearly. We're talking about taking a zip file and unzipping the contents of it into a folder. If that is not something you are capable of doing, well, this process is probably not going to go well. I know that sounds harsh, but, the simple reality is that basic computer skills ARE required in order to flash phones.
Posted 22 May 2014 - 09:20 AM
Ok. will get back to You later on with any progress. Thanks
Posted 22 May 2014 - 01:21 PM
I've done it follow Your post, but in HouseOfMoto says that didn't find file (RSD or Fastboot). I've sent You House.txt file:
POST THE CONTENTS OF THIS FILE IN THE HoM THREAD
FASTBOOT DEVICES:
FILE STRUCTURE:
Wolumin w stacji C to WIN7
Numer seryjny woluminu: BB5A-E2E9
Katalog: C:\HouseOfMoto
2014-05-22 22:59 <DIR> .
2014-05-22 22:59 <DIR> ..
2014-05-22 22:23 281 CreateLOG.bat
2014-05-22 22:57 4 flashmode.ini
2014-05-22 22:50 975 FXZ_xt
2014-05-22 22:50 <DIR> FXZ_xt####
2014-05-22 22:59 95 house.log
2014-05-22 22:23 13˙094 HouseOfMoto-ScriptGenerator.jar
2014-05-22 22:23 4˙855 HouseOfMoto.bat
2014-05-22 22:23 2˙877 HouseOfMoto.sh
2014-05-22 22:54 7 phone.ini
2013-11-23 18:07 <DIR> root
2014-05-22 22:24 <DIR> rsd
8 plik(˘w) 22˙188 bajt˘w
Katalog: C:\HouseOfMoto\FXZ_xt####
2014-05-22 22:50 <DIR> .
2014-05-22 22:50 <DIR> ..
2014-05-22 22:43 11˙534˙336 boot_signed
2014-05-22 22:43 8˙160˙652 bos_signed
2014-05-22 22:43 54˙536˙192 cdrom_signed
2014-05-22 22:43 1˙462 CFC_9.8.2I-50_SMI-26_S7_USASMIJBRTEU.xml
2014-05-22 22:43 66˙528 dnx
2014-05-22 22:50 393 FULL_xt890.bat
2014-05-22 22:50 354 FULL_xt890.sh
2014-05-22 22:43 32˙768 gpt_signed
2014-05-22 22:43 1˙937˙660 ifwi
2014-05-22 22:50 366 KEEP-DATA_xt890.bat
2014-05-22 22:50 329 KEEP-DATA_xt890.sh
2014-05-22 22:43 875˙336 logo_signed
2014-05-22 22:43 23˙832˙048 motoboot
2014-05-22 22:43 17˙501˙930 motobp
2014-05-22 22:43 11˙534˙336 recovery_signed
2014-05-22 22:44 825˙135˙784 system_signed
2014-05-22 22:44 875˙336 ulogo_signed
17 plik(˘w) 956˙025˙810 bajt˘w
Katalog: C:\HouseOfMoto\root
2013-11-23 18:07 <DIR> .
2013-11-23 18:07 <DIR> ..
0 plik(˘w) 0 bajt˘w
Katalog: C:\HouseOfMoto\rsd
2014-05-22 22:24 <DIR> .
2014-05-22 22:24 <DIR> ..
2014-05-22 22:23 421˙978 BlankFlash.dll
2014-05-22 22:23 1˙106 cleancache.vbs
2014-05-22 22:23 86˙116 CommonXMLParser.dll
2014-05-22 22:23 49˙236 FBFlash.dll
2014-05-22 22:23 41˙054 FlashAdapter.dll
2014-05-22 22:23 172˙032 LCDriver_CNH1606432.dll
2014-05-22 22:23 69˙632 LCM.dll
2014-05-22 22:23 59˙856 libusb0.dll
2014-05-22 22:23 1˙159˙259 pst.dll
2014-05-22 22:23 26˙177 PST.ini
2014-05-22 22:23 23˙431 pst_flash.ini
2014-05-22 22:23 1˙630˙298 pst_fp_flash.dll
2014-05-22 22:23 172˙131 pst_fp_flashdevapi.dll
2014-05-22 22:23 45˙568 PST_INI.xls
2014-05-22 22:23 2˙292˙736 QtCore4.dll
2014-05-22 22:23 1˙504 RSDLite.ini
2014-05-22 22:24 53˙323 rsd_service.dll
2014-05-22 22:24 225 rsd_service.ini
2014-05-22 22:24 1˙973 sdk_common.ini
2014-05-22 22:24 2˙789˙448 SDL.exe
2014-05-22 22:24 397˙824 xfstk-dldr-api.dll
21 plik(˘w) 9˙494˙907 bajt˘w
Razem wymienionych plik˘w:
46 plik(˘w) 965˙542˙905 bajt˘w
11 katalog(˘w) 1˙899˙724˙800 bajt˘w wolnych
Posted 22 May 2014 - 01:49 PM
Uh, yea. That's because FXZ_xt#### is not a literal. You replace #### with the model of your phone. Which is also what the instructions say to do.
Posted 22 May 2014 - 02:26 PM
I've using HouseofMoto 2.3 and as per pictures it seems that something happens, but still no working. When i've tried using FASTBOOT it can't find file path and when i starting RSD it goes to RSD program nad stops on 3/10 and Restarting Droidboot on phone. What's wrong with it?
