Custom ROMs after 4.4 update?
bboyles4
, May 23 2014 04:11 PM
3 replies to this topic
Posted 23 May 2014 - 04:11 PM
I have searched several forums and can't find an answer so I will just ask. After updating to the official KK with an unlocked BL, custom recovery installed and root achieved is it still possible to flash custom ROMs? The reason I ask is because I've tried a few with the KK CWM recovery and gotten a status 7 error.
Posted 23 May 2014 - 09:13 PM
- bboyles4 likes this
Posted 24 May 2014 - 03:51 AM
Ok thanks. I also noticed for anyone else experiencing problems with the KK CWM, that you cannot mount or wipe data at first. I was able to fix this by doing a factory reset from settings and then immediately rebooting onto CWM. Now I can backup, mount, and wipe just fine.
Posted 24 May 2014 - 04:32 AM
Correct. The cwm for kk looks for your data partition to be f2fs and it will not be until you format your data partition.
Sent from my Unlocked Moto G
Sig by
