Bricked upgrading to Kit-Kat
5 replies to this topic
#1 Creepjack01
Creepjack01
Posted 23 May 2014 - 06:09 PM
Wanted to downgrade to reset all my files to get ready for 4.4 so.
downgraded to 4.1.2, went fine
Phone began installing the OTA update as normal
kicked into Fastboot half way through and is now stuck, wont turn off or restart or anything.
Screen reads as follows
AP Fastboot Flash Mode (S)
10.9B(*) (sha-1e9f557, 2013-05-25 01:04:26)
eMMC Info: Size 16GB
Device is LOCKED, Status code:0
Battery OK
Connect USB
Data Cable
downgraded security version
update gpt_main version failed
failed to hab check for gpt_backup: 0x35
failed to load GPT
CID read failure
Invalid CID status 0x69
no sp partition found
Fastboot Reason Invalid GPT
USB Disconnected
Any Ideas on a fix?
#2 miss_sticks
miss_sticks
    Lurker Extrordinaire
  • 382 posts
  • Current Device(s):xt1687
Posted 23 May 2014 - 06:39 PM
Try following the instructions in this thread:
Please read everything before doing anything!
  • Creepjack01 likes this
#3 Creepjack01
Creepjack01
Posted 23 May 2014 - 06:45 PM
downloading the FXZ now, I'll let you know how it goes.
#4 Creepjack01
Creepjack01
Posted 23 May 2014 - 07:13 PM
WORKED! Thanks so much! ended up having to do a full install, but its working! lifesaver!
  • miss_sticks likes this
#5 miss_sticks
miss_sticks
  • 382 posts
Posted 23 May 2014 - 07:16 PM
I'm glad you got it working!
Thank Mr. Samuri.  He did all the work.  :)
#6 evolume
evolume
  • LocationUnited States
Posted 23 May 2014 - 08:34 PM
I followed OP instructions and everything worked. Interesting side note though: Ive never been able to get RSD Lite to install on this computer (Windows 7, 64 bit). I always get an error and have never been able to resolve it. I even had the same problem 3 years ago and posted about it here:
anyway, I was able to use my old WinXP laptop, and after updating Java and USB drivers, it worked like a charm.
Thanks!
