Bricked my Droid Razr M?
9 replies to this topic
#1 MxPhenom216
MxPhenom216
Posted 24 May 2014 - 12:02 PM
I have an unlocked bootloader and didnt know that I shouldnt do an OTA update. First time it got stuck in a boot loop showing the WARNING BOOTLOADER IS UNLOCKED message. used AD Fastboot to flash back to stock 4.0.4 rom. That worked fine. Decided to try the OTA update again, see if it was just a bad update or something. This time, phone isnt even booting. Frozen at a black screen, rebooting is not fixing it. No amount of time of holding the power bottom or combination of the up and down volume is fixing it.
Am I SOL? Next step to go to Verizon or contact Motorola?
#2 Donald21413
Donald21413
  • 23 posts
  • Current Device(s):XT907
Posted 24 May 2014 - 03:51 PM
I would contact Motorola first, as Verizon tends to be babies about people with unlocked bootloaders. They wouldn't replace my two-day old Razr M with a faulty vibrate motor because I unlocked BL. I know there's a special cable you can buy that lets you charge battery while bricked, and a bad battery could be your issue. Maybe. I'm not an expert by any means but I am trying to help :p
#3 SamuriHL
  • 43,479 posts
Posted 24 May 2014 - 06:04 PM
#4 Someolddude
Someolddude
  • 426 posts
Posted 25 May 2014 - 03:15 PM
Follow post 3. I had an issue trying to take the ota and fixed it good as new. You just need fastboot.
#5 mylesfool
mylesfool
Posted 11 August 2014 - 03:51 AM
I'm having a similar problem! I unlocked the bootloader and now I am in a constant loop when the phone is plugged into a power source. If the phone is unplugged there is nothing going on with it, (no LED, No fast boot) nothing. Any ideas?
#6 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 11 August 2014 - 04:01 AM
Just unlocking shouldn't put it into a bootloop.  Did you do anything else at the same time?
#7 livinginkaos
Posted 11 August 2014 - 04:02 AM
I would not mess around and just flash the fxz.
sent from my G3
  • RikRong likes this
#8 SamuriHL
  • 43,479 posts
Posted 11 August 2014 - 04:06 AM
If it doesn't boot after flashing the FXZ, then you're going to need to FDR the thing.
#9 mylesfool
mylesfool
Posted 16 August 2014 - 09:40 AM
Sadly this is where I am at a complete stump, I did not do anything else to the device besides unlock the bootloader, no flashing, nothing... My device isn't even recognized by RSD lite and i'm not able to obtain fastboot (pwr, vol+,vol -). I'm at a complete loss, Should i just send it off to get Jtag'd ?
#10 xKroniK13x
xKroniK13x
  • 284 posts
  • LocationAtlanta, GA
  • Current Device(s):Moto X 2014 Pure Edition || Motorola DROID RAZR M || Archos G9 101 || Microsoft Surface Pro 2 || Chromecast
Posted 17 August 2014 - 07:31 AM
When connected to your computer, go to device manager and see what your device is listed as.
Sent from my RAZR M (CM Nightlies) from Tapatalk Pro.
Moto X 2014 Pure Edition Unlocked on Pure Rooted 5.1
