Hey ladies and germs, I've had the razr maxx since late spring and finally got the cajones to root and then flash a ROM to it. After what feels like years of youtubing and reading forums I still somehow feel like I have no idea what I'm doing. Are there any tips/preferences/apps I should know about? Anything I should definitely NOT mix together?
so far I've gathered
-never run safestrap and bootstrap at the same time
-it's probably a good idea to get a file manager of some sort
-titanium backup can be helpful (if you know what you're doing)
and personally I'm looking for something a little more themed/drastic visually or some sort of jellybean leak perhaps? If anyone has any thing to add it would be a big help! thanks in advance!
First Smartphone, First Root
sub
, Sep 29 2012 02:23 PM
2 replies to this topic
Posted 29 September 2012 - 02:23 PM
Posted 29 September 2012 - 02:36 PM
If its cdma version search forum for matts utility 1.8 it will have everything u need to root. Personally I wouldn't even bother with bootstrap just get safestrap which is also included in matts utility.
Sent from my Droid Razr using Xparent SkyBlue Tapatalk 2
Posted 30 September 2012 - 04:47 AM
Theme is Googlebean. Well worth the $1.99.
