Cpu Master
Posted 15 January 2012 - 07:36 PM
On the main screen you can pick the max & min MHz what are the best to use? There is also the scaling with in that is mot_hotplug, hotplug, ondemand, userspace & preformance. I have no clue what these mean so no idea which one would be best to use & set on boot should i check this?
Then there is the advance tab.
I/O Scheduler & you have noop, deadline & cfq again no clue what they mean or do.
also on the tab if you pick ondemand from the main tab there is
sample rate (3000 us-1)
up threshold (1%-100%)
ignore nice load (0/1)
Powersave bias (0-1000)
If using ondemand what should these be set at?
Also Set on boot should this be checked?
Thanks for all your help.
Posted 15 January 2012 - 08:11 PM
Signature Loading.................
Posted 15 January 2012 - 10:09 PM
Posted 16 January 2012 - 08:04 AM
Posted 16 January 2012 - 07:04 PM
Posted 23 November 2012 - 02:46 PM
Posted 24 November 2012 - 06:42 AM
Sent from my MZ617 using Tapatalk 2
Posted 25 November 2012 - 05:51 PM
Sent from my DROID SPYDER using Xparent Green Tapatalk 2
Posted 27 November 2012 - 08:34 PM
Yes, you can over clock to about 1350mhz and some phones don't even like that. I'll post a link in a little while. There's only 1 way to do it. It's with a special governor that was written to allow overclocking.
ever get around to that link?
