[Xda] Pimp My Rom (Flashable Zip)
Posted 04 October 2012 - 02:13 PM
I was flipping through Google reader (best app highly suggest it ) and I saw a lofehacker article linking to this XDA thread of a ROM add-on with a bunch of cool init.d scripts and other fun stuff you can flash on top of your current ROM whatever it is! I wanted to share the link with you guys and hear some feedback
I am downloading it right now but I'm not flashing it ATM BC I don't see the need for it in Israel and I want a phone as stable as possible (I'm on Flick now instead of some crazy jellybean nightly )
Please let me know how it goes for you guys and if it goes well I might give it a shot
- emiliobadillio, JJT211 and Olao99 like this
Posted 04 October 2012 - 02:17 PM
Posted 04 October 2012 - 04:21 PM
Posted 04 October 2012 - 04:22 PM
Sent from my XT912 using Xparent Blue Tapatalk 2
Posted 04 October 2012 - 04:56 PM
Edit: I modified the "META-INF/com/google/android/aroma-config" file and changed the theme from miui4 to ics and now I can read the selections on aroma.
Has a TON of tweaks. I'll post some results after I experiment some more.
Edited by superrelaxx, 04 October 2012 - 06:33 PM.
Posted 04 October 2012 - 10:19 PM
Could it be a safestrap problem? The OP said CWM or TWRP
#7 Guest_BDH_*
Posted 04 October 2012 - 11:27 PM
1. Take the META-INF folder from whatever ROM you're running and put it on your desktop.
2. Use 7zip to "Open Archive" of the "Pimp My ROM" zip file.
3. Copy the META-INF folder from your desktop into the root of the "Pimp My ROM" zip file.
4. Close out 7zip, put the zip on your sdcard and flash.
The issue is that the zip file for the "PMR" tweaks was apparently a previous zip file for a theme for a different phone. That's why the install aborts. It needs the META-INF folder of whatever ROM you're running in the zip file. Hope that helps everyone
Posted 05 October 2012 - 12:20 AM
Easy way to fix the install issue.
More specifically and per the OP,
- Open the zip of the rom you are running (the .zip file that you flash in recovery)
- Inside this zip, navigate to : META-INF/com/google/android
- Extract the file called "update-binary" and rename it to "update-binary-installer"
- Open Pimp my Rom's zip (i.e : PIMP_MY_ROM-v1.4.1-Universal.zip)
- Inside this zip, navigate to : META-INF/com/google/android and delete "updater-binary-installer"
- Now copy the "update-binary-installer" file you extracted from your rom to Pimp My Rom's zip (still in META-INF/com/google/android)
There's other "stuff" in the META-INF folder that needs to be there. If the one from your ROM overwrites the entire folder, the install should fail as well.
#9 Guest_BDH_*
Posted 05 October 2012 - 12:52 AM
Pretty sure it will still work but whatever.
#10 Guest_24v_*
Posted 05 October 2012 - 04:21 AM
Yeah, but probably better to use the install script written for the file.Pretty sure it will still work but whatever.
Posted 05 October 2012 - 04:49 AM
Tried that, still got a status 7 when it tried finding aroma in a tmp folder..
Posted 05 October 2012 - 06:34 AM
What OS option are you choosing when installing?
Posted 05 October 2012 - 08:29 AM
"/tmp/aroma-data/backup.prop" No such file or directory
Status 7 Aborted
Same thing happened on both files.
Posted 06 October 2012 - 07:49 PM
I have a droid razr maxx with stock rooted ics 4.0.4 and cant get pimp my rom to work. Where do I find the meta-inf for my rom. I have been look for hours and cant find it.
Posted 06 October 2012 - 07:57 PM
Somebody please help me!!!!
Open the rom zip file and you'll see this: 45.63KB 45 downloads
Posted 06 October 2012 - 07:58 PM
Where is my rom zip fileOpen the rom zip file and you'll see this:
Im on stock 4.0.4
Posted 06 October 2012 - 07:59 PM
Posted 06 October 2012 - 08:05 PM
Posted 06 October 2012 - 08:14 PM
Posted 06 October 2012 - 08:29 PM
