Accidentally Uninstalled Safestrap
KrNpRiDe
, Oct 09 2012 02:37 PM
5 replies to this topic
Posted 09 October 2012 - 02:37 PM
Hi, I am new to the forum and this is my first post.
I have Droid Razr Maxx and installed custom ICS rom with Safestrap.
I have been using the Rom for awhile and wanted to install JB rom for testing.
So I wanted to Dual boot using Boot Manager and it requires Bootstrap.
This is where problem occurred. I uninstalled Safestrap and rebooted the device.
And now it just hangs on the boot screen.
Is there a way to fix this without wiping everything?
I have a lot of important information on the phone that I can't afford to lose.
Please help. Any help will be greatly appreciated.
Thank you.
Thank you.
Posted 09 October 2012 - 02:56 PM
if you still have ss menu try toggling to unsafe side,if that doesn't work you may have to fastboot,sorry to say but you should have read a little more before you did that
Posted 09 October 2012 - 03:44 PM
How exactly did you go about uninstalling safestrap? Did you just installed the apk?
Posted 10 October 2012 - 04:36 AM
nandroid backup?
Posted 10 October 2012 - 05:08 AM
Did you make a ROM backup in BM before you rebooted? If so, there will be a zip file in your backups starting with BM for its name, and you can flash it in recovery.
Otherwise, as other posts noted, you'll have to wipe it, then reinstall. But if you came to unsafe side before installing BM, SS automatically made a copy of your safe side ROM that you can flash once you have SS installed again.
Sent from my DROID SPYDER using Xparent Blue Tapatalk 2
If you PM me here, I'll get it eventually, but I'm constantly on the move. If you need to reach me more quickly, email me at stealthmouse@gmail.com and add DroidRZR PERSONAL MESSAGE to subject line. Thanks!
Posted 10 October 2012 - 05:21 AM
Try using option 1 in matts utility. The last step will ask you press any button to wipe data or exit to continue.
If you exit the program then you should be able to keep data.
Hopefully this works but you might end up having to wipe data because you are coming from safe side. Goodluck.
Sent from my RAZR MAXXIMUS
