Smart Actions
nix80908
, Jan 17 2012 10:09 PM
5 replies to this topic
Posted 17 January 2012 - 10:09 PM
What are your favorate Smart Actions?
What are some that don't work well?
I wanna hear some of your most creative Smart Actions usage. Maybe get some ideas of my own.
Posted 17 January 2012 - 11:25 PM
I normally use only 2-3 smart actions.
1) ON
When:
- Display = On
- Cellular Data = On
- Brightness = 0%
- Background Sync = Off
When:
- Display = Off
- Cellular Data = Off
- Background Syncing = Off
When:
- WiFi = (my wifi connection)
Posted 18 January 2012 - 06:57 AM
I have a few:
Basically the default battery extender: Display off, not charging, not moving = turn gps, bt, and background sync off
Then two rules triggered by my work WIFI and home WIFI = disable cellular data, turn gps and bt off
I also have a timeframe setup for MOST of the workday to ensure the BT and GPS stay off no matter what.
I get excellent battery life.
After that I have one that is triggered by my car dock, and one for my desk dock to turn different settings on or off.
I really hope they continue to tweak this app as it's great but could be better.
Posted 18 January 2012 - 10:11 AM
i got quite few.
triggers: wifi connection
actions: cellular data disable
triggers: location
Actions: Ringer volume 50%, display timeout 2min, brightness 100%, background sync on
triggers: display off, no movement
Actions: background sync off, bluetooth off
Name: nighttime battery saver
triggers: timeframe night (12pm-7am), display off, no movement
Actions: disable background sync, wifi off, bluetooth off, brightness 0%, cellular data disable
triggers: headphones plugged in
Actions: launch "my music"
triggers: charging (wall adapter), headphone unplugged [this is just so it dont interfere when im charging in my car]
Actions: bluetooth off, background sync off, brightness 0%, display timeout 15 sec
Name: low battery saver
triggers: battery level < 20%, device not charging
Actions: brightness 0%, background sync disable, bluetooth off, display timeout 15 sec, gps off
triggers: location
Actions: ringer volume vibrate, bluetooth off, brightness automatic, cellular data enable, display timeout 1min
triggers: location
Actions: ringer volume vibrate, background sync off, cellular data enable, display timeout 1min, brightness automatic
thats pretty much all of mine. non of them are conflicting and it saves me alot of batter when not in use.
i actually managed to squeeze out more than 8 hours on my phone. hope this helps.
triggers: location
triggers: location
triggers: location
- pinoy_92 likes this
Posted 18 January 2012 - 02:59 PM
Trigger:Location
Action:Ringer volume vibrate, display timeout 15s
Trigger:Location
Action:Ringer volume 100%, Display timeout 5m
Trigger: Wifi connection
Action: Disable cellular data
Trigger: Display off
Action:Cellular data disabled
Trigger: Display on
Action:cellular data enabled
I also run JuiceDefender which handles disabling cellular data when using specific apps (playing most games for example), disabling WiFi when I'm not at a prefered location, disabling Bluetooth after 1m of no device connecting (enables at screen on and when a call starts). Could just use Tasker or something for that easily as well, but I already owned a JuiceDefender Ultimate license anyways
Trigger:Location
Trigger:Location
Trigger: Display on
- dubz242 likes this
Posted 18 January 2012 - 04:19 PM
I use automateit.
Trigger: car docked
actions: bt/GPS on, brightness 100, media vol max., start ionroad.
Opposite when undocked.
Trigger: device boot
Action: tts "holy s++t"
Trig: battery =15
Action: tts "razr needs charge"
Trigger: car docked
Trig: battery =15
