So, it's pretty well known, but not really discussed often enough to keep track of. Has the Bluetooth bug that causes crackling or terrible phone audio and the toggle issue been solved in any non-blur Rom? Kexec? ANYTHING? I'm dying to move to one of the incredible roms.
5 replies to this topic
Posted 10 October 2012 - 06:27 AM
Posted 10 October 2012 - 06:49 AM
I bet I got your hopes ui when you saw you had a notification! I don't really use Bluetooth for audio, but I think the problem still exist.
- MetalJR likes this
a what? an android? whats that?
Posted 10 October 2012 - 10:12 AM
The bug still exists so far as I've seen. Both the CM9/CM10 base roms as well as the AOKP base rom contain the bug, and so long as ROM developers use those bases then it will remain a problem for us bluetooth users. I think I read somewhere it's a kernel issue, but I haven't read any further than that.
I'm sitting tight on SuperDallas's RAg3 until there's further fixes implemented on this issue.
Posted 10 October 2012 - 10:27 AM
Bummer, that's what I was afraid of.
Dallas and Jester put out some good ROMS for us BT users, but development is snail paced and obviously limited.
Hopefully someone will crack it.
Posted 15 October 2012 - 02:13 PM
that would likely be more effort than its worth cause our kernel source is under lock and key for stuff like hdmi and webtop- Bluetooth can be fixed by routing through alsa (conf file is located in system/etc somewhere.
Posted 18 October 2012 - 05:48 AM
Thanks for the input.
I've never read anything related to the following:
"Bluetooth can be fixed by routing through alsa (conf file is located in system/etc"
Can you elaborate or provide a link?
Also tagged with one or more of these keywords: bluetooth, roms
