Slot 4 Cpu?
Posted 13 October 2012 - 01:10 PM
Can someone one explain slot 4 cpu :-)
Posted 13 October 2012 - 04:27 PM
Slot 4 is clock 4 in this pick. Its really just a frequency slot.
Posted 13 October 2012 - 05:05 PM
Posted 13 October 2012 - 05:25 PM
A 5 slot cpu basically allows another slot for frequency. A four slot CPU has 300, 600, 800, and 1000 Mhz slots by default if I remember correctly. A five slot CPU allows for an extra 1200 MHz CPU frequency. Hence, some people only have 1.0Ghz on the ICS leaks and some people have 1.2Ghz.
And at least one lucky person on here has a 7 slot Bionic ...tis not I though
Sent from my . 247 House of BIONIC Edition * Now with Jellybeans *Practicing my pirate speak.. and sounding stupid
Posted 13 October 2012 - 06:01 PM
So I have a four slot correct? What exactly does this mean for me? I have been on 1.2 since the ICS leaks by default
Posted 13 October 2012 - 09:32 PM
Thanks everyone
Posted 14 October 2012 - 12:07 AM
yesWhat causes the amount of slot? Hacking? Or software written that way? Or is it a hardware thing?
Thanks everyone
- BleedsOandB and nitephlight like this
"We are the People Verizon warned you about"
8 GB Bionic JB, 16 GB Bionic JB, Bionic Lapdock X2, Razr Maxx XT912 JB, Razr M XT907 JBLX
Posted 15 October 2012 - 02:17 PM
yes
what he means is..
hardware silicon revision, not all bionics are created equal..
Posted 16 October 2012 - 09:12 AM
RUNNING the latest and greatest ICS 247.
Posted 16 October 2012 - 09:50 AM
None of that makes sense since you said 5 slots allow 1200 and 4 slots only allow 1000. But as above said he has 4 slots and has been running 1200? So what gives there?
You can manually do it, but those with 5 slots got it automatically with the ICS update. Look up Droid Bionic Overclock or Tweakerz on Google. You should find instructions.
Posted 16 October 2012 - 10:25 AM
Posted 16 October 2012 - 10:39 AM
Posted 16 October 2012 - 10:50 AM
Posted 16 October 2012 - 02:42 PM
But am i wrong then? Cause from what i understand i only have for slots right? And i definitely got that bump to 1200
You have 5....the "maxclock" is your 5th slot.
Posted 16 October 2012 - 04:02 PM
Posted 16 October 2012 - 05:49 PM
Thank you, i knew i was missing something obvious
No problem at all.
Posted 18 October 2012 - 08:17 PM
Posted 19 October 2012 - 05:19 AM
#19 Guest_HOFFA_*
Posted 19 October 2012 - 06:20 PM
Posted 20 October 2012 - 08:46 AM
- johnlgalt likes this
