Safestrap Splash Screen Not Coming Up
Posted 17 October 2012 - 02:09 PM
Posted 17 October 2012 - 02:35 PM
- Thach likes this
Posted 17 October 2012 - 02:37 PM
did you install recovery after installing app?
I actually forgot to do that the first time i used SS. Tried for a while to figure out what I was doing wrong till I slowed down and read everything. Sometimes its the simple things we overlook.
Posted 17 October 2012 - 02:39 PM
Posted 17 October 2012 - 02:41 PM
Posted 17 October 2012 - 02:45 PM
Posted 17 October 2012 - 02:47 PM
Posted 17 October 2012 - 02:49 PM
Posted 17 October 2012 - 02:51 PM
Posted 17 October 2012 - 03:10 PM
Posted 17 October 2012 - 03:37 PM
Posted 17 October 2012 - 04:15 PM
noThe OP says to move the safestrap files to the external SD, is that the same as deleting them?
Posted 17 October 2012 - 04:17 PM
you need to check int and external and remove all folders for both apps and start over.best advice is read op,it will explain how it works and where folders are locatedok i uninstalled v2 then i deleted the folders then reinstalled v2 still no go. Where are the safestrap folder at exactly?
Posted 17 October 2012 - 04:19 PM
Posted 17 October 2012 - 04:25 PM
Posted 17 October 2012 - 04:36 PM
Posted 17 October 2012 - 05:17 PM
Posted 18 October 2012 - 04:27 AM
- You will want to move the entire “/sdcard/safestrap” directory to the external SD card (/sdcard-ext). These are your backups and in a catastrophic situation you could revert to Safestrap v2 and use them.
- Go into the existing version of Safestrap and use the “Remove Recovery” button to remove the Safestrap files from the stock /system.
- And lastly, remove the APK from the device as you would any other app.
Posted 18 October 2012 - 05:14 AM
