So I was on .247 running speedlite 2.0. I tried switching back to safe side and my bionic died. Couldn't boot and tried to FXZ to .905 but keep getting a cdt.bin error... I don't know what to do! anyone please help!
Bricked Bionic
chriswho
, Oct 17 2012 05:51 PM
3 replies to this topic
Posted 17 October 2012 - 05:51 PM
Posted 17 October 2012 - 06:03 PM
You may find some help in this thread:
Congrats you tried to go back to Gingerbread from ICS. Not possible... See the bright red warning in the OP of the thread above.
Edit: I also moved this to the more appropriate Support forum...
Posted 17 October 2012 - 10:25 PM
With 232 you can go back to GB, but with 235 up you can't, what you can do is use HoB, and just install 247 again, it should fix your problem. Also, because 235 changes the kernel security, you can't safestrap back to GB, that is why when you install the ICS leaks there is a warning on all that are 235+ to uninstall Safestrap and Safeboot, it gives this error, I would install 247 again, and keep it as your only OS, since it should go live here in a few weeks, I am thinking pre Halloween, or at the latest possibly first week of November.
Droid Bionic Launch Version 16GB Internal w/ 16GB SDcard version with HoB 247 ICS.
Posted 18 October 2012 - 05:21 AM
Read my FAQ. The "I'm a moron and FXZ'd 905 on 235+..." section.
- medic likes this
