cm11 help
Best Answer thewraith420 , 05 July 2014 - 05:16 PM
You still haven't flashed the bootloader. I think it's something like emmc-??? Flashes to aboot partition Edit at this point your probably better off doing the whole update to kk Edit2: this could help http://www.droidrzr....NLY#entry445144 Go to the full post
7 replies to this topic
#1 Donald21413
Donald21413
  • 23 posts
  • Current Device(s):XT907
Posted 04 July 2014 - 06:24 PM
Probably know the answer to this, but.... To update to the new nightly build of cm11 it says I need to update my bootloader. This means I just flash the boot.IMG from the 4.4 update right?
#2 xKroniK13x
xKroniK13x
  • 284 posts
  • LocationAtlanta, GA
  • Current Device(s):Moto X 2014 Pure Edition || Motorola DROID RAZR M || Archos G9 101 || Microsoft Surface Pro 2 || Chromecast
Posted 04 July 2014 - 06:40 PM
That may work, but I'd just do a full FXZ flash to KK and then flash the new TWRP version and go!
Sent from my DROID RAZR M using Tapatalk
Moto X 2014 Pure Edition Unlocked on Pure Rooted 5.1
#3 Donald21413
Donald21413
  • 23 posts
Posted 04 July 2014 - 06:46 PM
Would like to keep my current data and all from cm11 though. Wouldn't the fxz get rid of all my cm stuff?
#4 xKroniK13x
xKroniK13x
  • 284 posts
Posted 04 July 2014 - 07:15 PM
There is a keep data script generated with this tool, can't guarantee what it will and won't safe with cm11. Samurai would be able to answer any questions you need, post it in that thread.
#5 Donald21413
Donald21413
  • 23 posts
Posted 04 July 2014 - 08:13 PM
Yeah, the RSD generator tool is just for flashing FXZ updates. I tend to just fastboot flash those kinds of things over, anyway. Takes longer, but I've had issues with RSD. I'm assuming all I need is the correct 4.4 boot.img to get the CM11 update to flash correctly.
  • xKroniK13x likes this
#6 Donald21413
Donald21413
  • 23 posts
Posted 05 July 2014 - 11:13 AM
BUMP: tried just flashing boot.img from a 4.4 update, now I'm softbricked. What do?
EDIT: Flashed boot.img and NON-HLOS.bin from new update and the 4.4 version of CWM. Still stuck on "this package is for devices with 4.4 bootloader", but can't boot into system with current boot and modem images, can't get to system because I'm not sure if the 9.8.30 FXZ has the right kernel or anything for the version of Cyanogen I was moving from.
Edited by Donald21413, 05 July 2014 - 11:30 AM.
#7 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
  • Current Device(s):XT907 jbbl Blisspop
Posted 05 July 2014 - 05:16 PM   Best Answer
#8 Donald21413
Donald21413
  • 23 posts
Posted 09 July 2014 - 08:01 AM
That will help for next time. Ended up just doing an FXZ flash and starting from scratch after manually backing up everything I wanted to keep. Thanks for the help though.
