I cant be the only person wondering this...
dont need every clck just a rundown of the steps please..
thanks in advance.
(fwiw simply installing 246 via HOB didnt work for me)
247 + Boostrap + Deodexed How Do I Go To 246?
mtbrgeek
, Oct 18 2012 02:48 PM
8 replies to this topic
Posted 18 October 2012 - 02:48 PM
HOBite running .247 .246
Posted 18 October 2012 - 03:08 PM
OK, following HOB FAQ which states to tyr a 246 reinstall didnt work either.
Posted 18 October 2012 - 03:16 PM
Did you use hob and select install or reinstall 246? If you skip steps it won't work
Posted 18 October 2012 - 03:48 PM
ya ive done both, skipping no steps.. going to try redownloading the hob 246 component ( even though it passes hash)
Posted 18 October 2012 - 04:03 PM
Im not fixed yet but it looks like i have the wrong RSD
if its 6.somethign thats wrong i tneeds to be 5.something...
heres a link to the good one..
Posted 18 October 2012 - 04:14 PM
It was the RSD version..
Posted 18 October 2012 - 04:27 PM
ya for bionic you should have 5.7.. the 6.14 is for the Razr
**So ive always held out on adding a donate link because this is just something i do for enjoyment.. but i have received a few requests recently to add one.. so if you enjoy my work and would like to buy me a beer or put some gas in my car, that would be very much appreciated.. but please continue to freely enjoy my mods without any feeling of obligation what-so-ever.. the last thing i want by adding this is for people to stop using my mods because they fell obligated.. Thanks
Posted 23 October 2012 - 04:04 AM
OP did you get back to 246? I was in same situation, 247 deodexed, with the atrix/razr flashables and when going to 246 it would hang at Android is upgrading finishing boot screen. however if i FDR'd it it was fine.
Marksmanship is next to godliness
Posted 23 October 2012 - 04:31 AM
Okay nevermind fixed that issue, had to boot into clockwork recovery, and run all the uninstaller scripts from the Atrix/Razr-M flashables page and unfreeze stock homescreen, then use HOB to flash 6.7.246 and now everything is peachy once again.
