Possible To Fxz 905 From Ota 246?
kijoko
, Oct 21 2012 05:57 PM
5 replies to this topic
Posted 21 October 2012 - 05:57 PM
Already fxz to 905 from 232, prepare to get 246 OTA, but need confirmation about possiblity fxz to 905 from 246, if anything going wrong is there a way to get back to 905 or 232?
thank you
thank you
Posted 21 October 2012 - 06:02 PM
no. different securities. but house of bionic can help if you have problems
Posted 21 October 2012 - 06:05 PM
thank you
Once on 246 do not try to go back to 905. Doing so will turn your phone into a very expensive paper weight (i.e. brick the effer). Furthermore you cannot return to the 232 build or lower due to security reasons in the software. If you are not rooted and are going to wait for the official ota then if by chance something goes wrong vzw will have to help you. If you are adventurous search for the House of Bionics thread. You will not have to wait for the ota.
Posted 21 October 2012 - 06:56 PM
To put it more bluntly:
If you try to go from 6.7.235/.238/.239/.242/.244/..246/..247 tp anything before those you WILL soft brick your phone.
And if some $#!7 for brains tells you he did it in BS or SS and it can be done, don't believe him. You cannot just replace the system file sand have a fully installed version. You only have the system files corresponding to that version.
IOW: ICS OTA is a no going back to GB one way street.
Posted 21 October 2012 - 08:11 PM
Thanks guys
Webtop, is there ebtop on 246? really love webtop and hdmi out...
Posted 21 October 2012 - 09:26 PM
Yes, there is webtop. It's not like in GB, but it is there.
