Help with Root
Posted 24 October 2012 - 08:04 AM
I did not run HOB.
Now I am trying to root with no success.
I'm stuck when I run Razrs Edge.. It ways "waiting for device"
Posted 24 October 2012 - 08:07 AM
Posted 24 October 2012 - 08:10 AM
I can just share what I did
1. I downloaded the latest moto drivers and razrs edge tool from obsidians post in this forum
**** moto drivers for windows -
**** razrs edge tool -- (click File, download and it will download all files as zip)
2. Installed latest moto drivers
3. MAKE SURE USB DEBUGGING IS ENABLED IN YOUR PHONE
4. Plugged phone into computer in USB mass storage mode, let it find drivers and finish - when done - you should see external and internal SD cards
5. Change USB mode to Media - let it install drivers - I then see a pop up when done with a window that shows droid bionic
6. This is optional - I then change to picture mode - let it install drivers, when done, I went back to media mode
Now, open run.bat in razr's edge tool and follow instructions.
This is assuming you're running windows (I am running windows 7)
I tried all that with no success.. Can someone please help??
Posted 24 October 2012 - 08:12 AM
I get stuck when I run Razrs edge. It gets stuck at Waiting for Device.
Posted 24 October 2012 - 08:26 AM
Posted 24 October 2012 - 08:32 AM
Should I just FXZ back to 905 and start again using HOB this time?
I've tried 3 pc's and 3 different cables with the same result everytime.
Waiting for device...
Posted 24 October 2012 - 08:33 AM
Posted 24 October 2012 - 08:34 AM
Posted 24 October 2012 - 08:35 AM
Posted 24 October 2012 - 08:42 AM
When I plug my phone into PC, my pull down menu shows USB debugging connected and Connected as a media device.
All the drivers installed correctly for the 3 usb settings you can choose from in phone.
I think I am just going to FXZ back to 905...and use HOB method.
Don't know what else to try.. I have rebooted my phone and pc too..
Posted 24 October 2012 - 09:42 AM
Posted 24 October 2012 - 09:47 AM
Since youre on 246 you WILL brick your phone if you go back to 905...
I guarantee you that sam wont help you if you brick this way... just sayin..
Posted 24 October 2012 - 11:48 AM
After that, I tried to use the root tool from HOB utility and I have the same issue "waiting for device"
RSD works fine.. I don't know.. I am reinstalling drivers again to see if that works
Posted 24 October 2012 - 12:32 PM
It connects correctly when I plug it in and all drivers install correctly..
completely uninstalled all motorola drivers and reinstalled using the link from HOB.
rebooted rc and phone and tried again... still not working..
Posted 24 October 2012 - 01:40 PM
Posted 24 October 2012 - 02:56 PM
Posted 24 October 2012 - 02:57 PM
Posted 24 October 2012 - 03:06 PM
Posted 24 October 2012 - 04:40 PM
Posted 24 October 2012 - 04:49 PM
