Bricked My Bionic...help?
32 replies to this topic
#1 LinkCable
LinkCable
  • 6 posts
Posted 25 October 2012 - 08:10 AM
I've been trying to get the ICS OTA for my Bionic for the past few days know, and doing so I inadvertently bricked my Bionic.
I was running stock .905, with the only change being that I was 4ever rooted.
Apparently this causes a problem in the OTA, so following the directions is this thread (
I deleted those last three lines in system/bin.
However, now when I start up the phone I am stuck in aa loop.
I installed RSDLite 5.7 but my Bionic does not show up, any suggestions on what to do?
EDIT: Does it not show up because my battery is low? I am using the Motorola supplied micro-USB cable. IS there any way I can charge my Bionic if it's stuck in bootloop?
#2 Mustang02
Mustang02
  • 27 posts
  • LocationCleveland, Ohio
Posted 25 October 2012 - 08:28 AM
Only if you have a dev cable. Anybody near you that could charge your battery for your?
And when you say doesn't show up, do you mean when you hold the volume up/down and power, and then select fastboot, it doesn't appear there?
#3 LinkCable
LinkCable
  • 6 posts
Posted 25 October 2012 - 08:36 AM
Not that I know of. :[
I'll have to ask around my friends.
And yeah, my Bionic doesn't show up despite being in fastboot.
And when I have the phone plugged into a charger a battery with a question mark on it is displayed on the screen. Good thing or bad thing?
#4 tucstwo
  • Google+:tucstwo@gmail.com
Posted 25 October 2012 - 11:01 AM
Bad thing, means it's not seeing your battery. You need a "factory" cable or an adapter to flash it without a battery or you need someone with a bionic to charge your battery. You're lucky to have that option. The razr folks are beat unless they want to take their phone apart and charge the battery that way.
#5 LinkCable
LinkCable
  • 6 posts
Posted 25 October 2012 - 11:10 AM
So, this?
#6 tucstwo
Posted 25 October 2012 - 11:18 AM
So, this?
Yes sir. That allows you to plug in your phone and circumvent the battery. That will power up device regardless of a present battery or not.
#7 LinkCable
LinkCable
  • 6 posts
Posted 25 October 2012 - 11:47 AM
Sweet, thanks. I just ordered it. Hope I can save my phone.
#8 SamuriHL
  • 43,480 posts
Posted 25 October 2012 - 03:09 PM
You need to put the phone in AP Fastboot mode for it to show up in RSD. Power + Vol down.
#9 jammasterkx2
jammasterkx2
Posted 26 October 2012 - 06:06 PM
You can cut the end off a usb cable, and connect red-black wire to battery to charge if phone is bricked.
#10 B.E.McAllister
B.E.McAllister
    Paint by Number Master
  • 355 posts
  • LocationUT, PA
  • Current Device(s):Bionic
Posted 29 October 2012 - 10:00 AM
Thought i read somewhere if you choose the BP option in recovery that it would also charge the battery
#11 LinkCable
LinkCable
  • 6 posts
Posted 31 October 2012 - 08:34 AM
I got the dev cable in the mail today, but when I plug in the adapter into my computer I just keep getting the bootloop and can't get to Fastboot. =/
Also my computer tries to install an XT875 driver despite me having downloaded all the drivers off of MOTODEV.
My phone is still not popping up in RSDLite! My phone is displaying:
Battery OK
OK to Program
Transfer Mode:
USB Connected
#12 B.E.McAllister
B.E.McAllister
  • 355 posts
  • LocationUT, PA
Posted 31 October 2012 - 09:17 AM
Maybe try uninstalling rsd lite and using 5.6
#13 LinkCable
LinkCable
  • 6 posts
Posted 31 October 2012 - 09:19 AM
Got it, thanks to this thread.
Turns out I had to run RSD as an administrator.
What a headache.
#14 Brutus06
Brutus06
    Drunken Monk Brewery
  • 407 posts
  • Google+:leereitz12@gmail.com
  • LocationSouth Dakota
  • Current Device(s):Bionic(retired), Lenovo Tablet, Moto G
Posted 19 December 2012 - 10:44 PM
I know this is an old post but for anyone that may read this. If you are impatient or cant wait for the shipping of a factory cable, I purchased an extended battery which normally comes 50%-75% battery life. This was enough battery to get my phone unbricked. Just a helpful hint for anyone that may stumble across it.
#15 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 26 December 2012 - 11:54 AM
Interesting. I just suggested to another person on another forum to do exactly that b/c of the fact that it comes pre-charged....
At least now I can point to your post as proof in case anyone asks lol. Thanks!
Sent from my ASUS Transformer Infinity TF700 running Android JB (rooted) via Tapatalk
#16 Brutus06
Brutus06
  • 407 posts
Posted 26 December 2012 - 02:10 PM
they aren't fully charged so best to get the extended battery, which will give you a little over a normal battery charge.
#17 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 27 December 2012 - 01:36 AM
Yeah, that is exactly what I suggested to a user over at XDA.
#18 Brutus06
Brutus06
  • 407 posts
Posted 27 December 2012 - 01:41 PM
The hardest part with that suggestion is where to find one. The only place I was able to find mine was at a battery store, phone retailers didn't carry them.
#19 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 27 December 2012 - 02:03 PM
Not surprising. I purchased mine immediately when VZW put then on sale for $25 - bought, actually. I don't think they have them anymore....
Sent from my ASUS Transformer Pad TF700T using Tapatalk HD
#20 Brutus06
Brutus06
  • 407 posts
Posted 27 December 2012 - 02:20 PM
Verizon, Best Buy, and Used cell store didn't have them here.
