I was going to create a boot animation for a theme I'm working on, but I became distracted and created this instead!
I thought I would share just in case someone is looking for something like this.
NOTE: The colors in the .gif above are slightly distorted as you can probably tell. The real animation is a little smoother in color than this.
Installation:
The easiest way to install this is to use Root Explorer.
- Download the file:
- Copy the file and navigate to /data/local (this will mean the stock boot animation in /system/media will remain unchanged). Paste it.
- Once pasted under /data/local, tap and hold on file. Go to Properties and change permissions to: rw- r-- r--. Press OK.
- Reboot and enjoy!
