Codename Android
Roms Bionic
19 replies to this topic
#1 jayrod
jayrod
  • 6,525 posts
  • LocationWilmington NC
  • Current Device(s):Taimen
Posted 26 October 2012 - 07:56 PM
I recently came across this Rom from Hascodes site for the Bionic : STOCK-JB-cna_targa-20121022.zip , and so far I like it but....I can't seem to find Bionic specific FAQ or even any info pertaining to much besides Nexus devices ,Tablets and S3..
And I don't see much info around here about it. Only found one issue thus far with it..NO camera seems to work period. The usual JB workarounds, Camera360,CameraFX don't work with it..or at least I can't get it them to.
Does anyone know where I can find info for the Bionic release?
#2 Brandroid1984
Brandroid1984
  • 136 posts
  • Twitter:@brantuck84
  • Google+:brantuck84@gmail.com
  • LocationCullman,Al
Posted 27 October 2012 - 03:36 AM
I have cna in one of my slots and i use lgcamera from the market and it works great no issues at all other than video cam not rec hd
Sent from a iCarus HD XT875 by brantuck84 aka bionic_bran
#3 jayrod
jayrod
  • 6,525 posts
Posted 27 October 2012 - 05:41 AM
Thanks! Weird that you can select it and it appears to record at a higher resolution but on playback it's not. Maybe it's because it's free
Sent from my Codename Android Edition Bionic
#4 nobreak1970
nobreak1970
    Transition Leader from Rombot
  • 130 posts
  • LocationAlabama
Posted 29 October 2012 - 08:09 AM
Awesome ROM.
God bless.
#5 King Howie
King Howie
    Minister of Jackbooted Thugs
  • 882 posts
  • Current Device(s):Galaxy S4 GPE, Nexus 7 (2013)
Posted 29 October 2012 - 01:03 PM
Updated today
#6 nobreak1970
nobreak1970
  • 130 posts
  • LocationAlabama
Posted 29 October 2012 - 01:08 PM
Sweet!
God bless.
#7 mhous33
mhous33
  • 480 posts
Posted 29 October 2012 - 03:20 PM
does front facing vidcam work? afaik this is still broken on all aosp based roms.
can someone verify whether the stock wifi tether app works on this? on the first build it would just hang when trying to turn it on.
#8 King Howie
King Howie
  • 882 posts
Posted 29 October 2012 - 04:56 PM
FFC locked up then FCed when I opened it. Tried to reopen it, and it said it couldn't connect to the camera.
WiFi tether opened, and activated. I didn't drag out my laptop and fire it up to connect, but it looks likely that it'll work
#9 mhous33
mhous33
  • 480 posts
Posted 29 October 2012 - 06:52 PM
thanks for checking the camera; i can live without front facing vidcam but would be nice if it worked.
good to hear wifi tether is working, will have to give this rom another shot.
#10 nobreak1970
nobreak1970
  • 130 posts
  • LocationAlabama
Posted 30 October 2012 - 07:33 AM
I have a problem with this rom....all is awesome....but Youtube doesn't buffer properly w/ multiple rebuffs on a fast wifi connection. (it is not my connection so that's a moot point before anyone brings that up)
I actually FXZed back to .246 on the bionic.
I installed this rom in slot 1 of Safestrap 3.
After install I wiped cache/dalvik
Youtube still will not buffer.
help?
God bless.
#11 mhous33
mhous33
  • 480 posts
Posted 30 October 2012 - 09:18 AM
so i ended up trying this and no, the wifi tether does not work, just like before. when i tap on it, it grays out and says it's connecting but never does, just like with the aosp base.
#12 Brandroid1984
Brandroid1984
  • 136 posts
Posted 30 October 2012 - 02:46 PM
I'm not sure but i believe this is a problem with all aosp jb builds though i may be wrong
#13 nobreak1970
nobreak1970
  • 130 posts
  • LocationAlabama
Posted 30 October 2012 - 03:21 PM
YouTube just doesn't work.
I've exhausted all possibilities.
I give up.
God bless.
#14 s.dubs
s.dubs
    Team Rage Developer
  • 83 posts
  • Twitter:@sdubs317
  • Locationcuse
  • Current Device(s):RAZR M
Posted 30 October 2012 - 03:33 PM
I give up.
I have inverted YouTube working great on my ROM. Haven't noticed any issues as of yet. Based on CNA10-29 build.
Help Support & Donate!
#15 nobreak1970
nobreak1970
  • 130 posts
  • LocationAlabama
Posted 30 October 2012 - 04:01 PM
Sdubs just flashed yours...YouTube still hosed.
God bless.
#16 rocketsaucev2
rocketsaucev2
  • 447 posts
Posted 30 October 2012 - 04:23 PM
Kind of annoying, my 'com.android.media' keeps stopping and all the ringtones are gone until I reboot, but it keeps happening
there are just a few things not working 100% for this to not be my daily driver, but it is close. I am loving cm 10, and if this gets everything working I will be all over it.
#17 BleedsOandB
BleedsOandB
  • 60 posts
  • Twitter:BleedsOandB
Posted 31 October 2012 - 02:37 AM
I give up.
I've had similar issues. Try checking high quality on mobile in settings.
#18 nobreak1970
nobreak1970
  • 130 posts
  • LocationAlabama
Posted 31 October 2012 - 06:00 AM
Ok and now it works. Didn't do a thing. ah well.
God bless.
#19 mhous33
mhous33
  • 480 posts
Posted 31 October 2012 - 01:23 PM
aokp and cm10 wifi tether works with no issues.
  • nitephlight likes this
#20 nitephlight
nitephlight
  • 82 posts
Posted 02 November 2012 - 10:08 AM
aosp builds lack hw codecs for YouTube (non flash) and Netflix I think. same for camera, hdmi etc.. it's just not in aosp source so incorporating would require bionic kernel source
