[Theme] Cm10 Themes Updated 11-08-12
Posted 26 October 2012 - 10:06 PM
Update 11-07-12
I added three more themes and now you can install all five themes together, no need to uninstall one in order in use another. This have been tested on AOKP BW jb 3.2 and it should work on any other AOKP or CM10 rom. Please note there are some differences between the two so some things will change when theme is applied and some will not. With that said lets move forward.
Update 11-08-12
Added two more colored themes, PinkN and Violet Eye
Credits
HashCode for the incredible SS3 which lets me do more
dhacker, CM devs, AOKP devs and all the Rom devs for the razr for giving us all these options
Annex for the cm10 theme template I used
Google for the OS
Moto for hardware
And anyone and everyone that has ever contributed in any way
Now for the themes.
Now there are five themes and I might port/create more themes.
Shady Blue
47.45KB 192 downloads
Golden Droid
51.06KB 209 downloads
Redify
46.61KB 128 downloads
Orange Andy
47.77KB 118 downloads
Leen Green
43.98KB 103 downloads
PinkN
47.98KB 95 downloads
Violet Eye
47.59KB 78 downloads
What was themed
framework
phone
contacts
keyboard
settings
systemUI
and maybe a few more might show
Installation
1.Download theme apk and save somewhere on your sd card
2.Make sure you have unknown sources checked in Security settings
3.Uninstall any previous theme versions of my CM themes
4.Locate where you saved the apk and click to install like any other app
5.After it installs go to settings>themes and scroll til you see the theme you want and click apply
6.You will get a "Theme error" message just click apply anyway and give it a reboot for it to take completely
7.Enjoy!! (optional)
ShadyBlue CM10 download -
Golden Droid CM10 download -
Redify download -
Orange Andy download -
Leen Green download -
PinkN download -
Violet Eye download -
Not expected but if you like you can buy me a
- lownslow200sx, andlaw, BytecodeMe and 2 others like this
Posted 26 October 2012 - 10:07 PM
Posted 29 October 2012 - 05:01 PM
Posted 30 October 2012 - 03:20 AM
Cool, glad you likeLoaded the gold one on my bionic flashed with speedlite Aokp, looks good and working nicely so far thanks!
Posted 07 November 2012 - 03:49 AM
15.61KB 40 downloads 16.94KB 43 downloads
- lownslow200sx likes this
Posted 07 November 2012 - 04:59 PM
Posted 07 November 2012 - 06:25 PM
Posted 07 November 2012 - 06:45 PM
Posted 07 November 2012 - 06:49 PM
Thanks, hope you like themVery cool thank you for the hard work
Nobody suggested it but I could do one.Any plans on doing a pink version?
Posted 07 November 2012 - 07:04 PM
Awesome, my wife wanted a pink version and at the moment I don't have the time to throw it together for her.
Posted 08 November 2012 - 05:12 AM
12.29KB 20 downloads
What, no purple?
15.51KB 19 downloads
Posted 08 November 2012 - 06:01 AM
Did someone say pink?
What, no purple?
That was quick.
Posted 08 November 2012 - 06:11 AM
Yeah, I finally organized my laptop so it can be easier to work with. Took a few days to get it setup but now I can update cm themes a little quickerThat was quick.
Posted 08 November 2012 - 03:03 PM
Enjoy!!!
Posted 02 December 2012 - 11:16 PM
what should I do?
thanks
Posted 02 December 2012 - 11:18 PM
I need in zip format. (blue one)
what should I do?
thanks
Why would you need it in zip format? If you are running cm10 just install it like any other app and go to the theme chooser in settings, apply,reboot, and enjoy.
Sent from my DROID BIONIC using Xparent ICS Tapatalk 2
Posted 02 December 2012 - 11:46 PM
Why would you need it in zip format? If you are running cm10 just install it like any other app and go to the theme chooser in settings, apply,reboot, and enjoy. Sent from my DROID BIONIC using Xparent ICS Tapatalk 2
only zip can be installed in Eclipse room.
Posted 03 December 2012 - 01:35 AM
These themes are for cm10/AOKP based roms, eclipse is from blur base so they won't work.
