Need Help Finding A Car Dock And Fm Transmitter
Posted 01 November 2012 - 07:30 PM
Anybody seen anything like this? or know the next best thing I could do?
Thanks in advance
Posted 01 November 2012 - 07:57 PM
The dock by Motorola will charge phone. Again, fm transmitter goes into headphone jack.
Posted 01 November 2012 - 08:30 PM
Posted 01 November 2012 - 08:39 PM
Posted 01 November 2012 - 08:48 PM
The option I chose to use was using the Motorola Car Dock for my Razr MAXX, and using a bluetooth FM transmitter (specifically, the Plantronics K100 [plt_k100]). It works overall fairly well, but I've had a few Android devices in my time, and have found bluetooth to be occasionally flakey (my Thunderbolt had the occasional habit of rebooting while paired to it), but usually acceptable. It also provided a microphone so I can take phone calls as well as stream Pandora, Soundcloud, or whatever (though obviously anyone listening to my frequency (and no, I'm not telling ... ) can listen to at least the other side of the phone call, though I imagine they'd have to be fairly close to pull that off). Since most of the time I'm using it for music streaming on my hour work commute, it's acceptable for me.
Don't you need bluetooth in your car to use the bluetooth transmitter?
Also does anyone have any sites I should check out?
Amazon is a mess for me to go through and when I do find what I'm looking for the reviews aren't so hot.
Posted 01 November 2012 - 09:49 PM
No, the car does not have to have bluetooth built into it. You pair your phone to the PLT K100 like any other bluetooth device, and tune your radio to one of the unused frequencies in your area in the (limited) range of frequencies it supports, and voila, you're in business. The combination I use would work in any car with an FM Radio.
As for sites, I bought my Plantronics at Verizon just because I was looking for something like it based on desire, and not based on any reviews I'd read, because the thing was pretty new at the time.
As for reviews of the PLT K100, you will probably find mixed reviews on it (just being honest). I'd love to find something with a greater frequency range, as the limited frequency ranges it supports in my area already have radio station overlap that is sometimes strong enough to overpower the signal from the Plantronics, but the same is likely true of any bluetooth FM transmitter.
As for links, here are some:
Plantronics K100 owner's manual:
Link to it on Amazon:
Motorola Droid RAZR Car Dock (not sure if the MAXX will fit this one or not, but mine looks like it; again, I got mine from Verizon):
Also, my wife has a Motorola Droid Roadster Bluetooth FM transmitter, and she likes that. She has a Droid Razr MAXX as well, and I've use my MAXX with both, and they both perform well. The only thing about one over the other is that the Roadster's voice prompts are male and not overly pleasant (though you get used to it), and the Plantronics voice prompts are female and much more pleasant; of course, that's my opinion, your experience may likely be different.
Posted 03 November 2012 - 08:30 AM
Posted 10 November 2012 - 07:55 PM
The gel sticks very well to the phone but doesn't leave a lot of residue. Held my phone going over speed tables at 30 mph.
Posted 15 November 2012 - 07:58 PM
As for car docks, I just use the Moto Razr cardock offered by Verizon. It does the job.
