Installed Sd Card, And Nothing...
Posted 03 November 2012 - 09:00 AM
Thanks!
Posted 03 November 2012 - 09:02 AM
Rockin' it with my Maxx, iKream and T-Talk
Posted 25 November 2012 - 07:09 PM
Posted 25 November 2012 - 07:48 PM
Posted 25 November 2012 - 08:09 PM
Posted 25 November 2012 - 08:12 PM
Posted 25 November 2012 - 08:42 PM
I installed an SD card from my old phone into my RMaxxHD, which seemed to be recognized by the phone. However, I am unable to move pics, apps, etc. to the SD card. Any ideas? Does the SD card need to be formatted for the new phone? If so, how to do this?
Thanks!
what size sd card and what class. this does make a difference. if its 32 or 64 than you shouldnt be above class 4 sometimes it wont even read that its there.
this is caused by the speed of the sd card itself. so this is one possibility
Posted 25 November 2012 - 10:03 PM
- karatche likes this
Posted 10 December 2012 - 06:38 PM
I have to disagree with you here VK, I got a Class 10/UHS-1 64 GB in my Razr, and it works fine after I properly formatted it (that wasn't quite fun, but only have to do it once)what size sd card and what class. this does make a difference. if its 32 or 64 than you shouldnt be above class 4 sometimes it wont even read that its there.
I believe the issue instead lies with the way the SD Card is formatted. An older phone may have slight formatting differences, or something corrupted.
Posted 10 December 2012 - 06:59 PM
I would lean more towards a bit different formatting..... That just happened to my wife... She "borrowed" our daughter's sdcard and couldnt access anything unless she put it in the computer.... Once she formatted it in the razr tho... She had full access to the new files on it.... (daughters phone is a older style non android)
sent from my spare phone tapadriving........
- Rycix likes this
