Enabling Navigation Keys... The Easy Way!
#1 Guest_rgocal_*
Posted 05 November 2012 - 07:42 PM
Most devs are making flashable zips to enable soft keys... no need to...
In your build.prop, enter the following line...
qemu.hw.mainkeys=0
0=enable
1=disable
So really knowing this, devs can enable a toggle in the the power menu or their own toolbox.
sent from my Droid Razr running Bionx Nx
- PillClinton, Gerland the Oracle, BytecodeMe and 2 others like this
Posted 05 November 2012 - 07:45 PM
Awesome find though...
#3 Guest_rgocal_*
Posted 05 November 2012 - 07:49 PM
Their may be a toggle for hardware keys as well possibly.
Posted 05 November 2012 - 09:13 PM
Posted 06 November 2012 - 11:19 AM
#6 Guest_rgocal_*
Posted 06 November 2012 - 12:53 PM
You can try the build prop tweak I always make the zip- only way to change size and I'm not sure if the build prop tweak will open the navigation bar menu in settings
Well yeah your going to need to edit the xml for size and which buttons to appear, however, this line allows users to easily disable and enable the nav bar via a build.prop editor. Gotta make things easier on the folks.
Ofcourse this tweak useless on aokp builds with the nav bar toggle option and tablet ui enabler.
Posted 19 November 2012 - 09:18 AM
Posted 19 November 2012 - 12:22 PM
Posted 19 November 2012 - 12:38 PM
Posted 19 November 2012 - 01:36 PM
Exactly. I'm on stock. 211 rooted with no custom ROM though.
Do you know how to push files to phone?
Posted 19 November 2012 - 03:08 PM
Care to explain how ?
Posted 19 November 2012 - 04:14 PM
Posted 19 November 2012 - 04:39 PM
Posted 19 November 2012 - 10:12 PM
Posted 28 November 2012 - 06:09 AM
- wabmorgan likes this
Posted 10 December 2012 - 10:04 AM
Posted 13 December 2012 - 09:17 PM
Btw, the soft key trick works, thanks!
Posted 13 December 2012 - 10:44 PM
One option is an app called AdjBrightness. Can lock off key lights.Is there any way to turn off led light for the hardware keys?
Posted 13 December 2012 - 10:53 PM
Posted 19 January 2013 - 09:44 PM
