4.2 Gapps
damagickid
, Nov 06 2012 09:13 AM
9 replies to this topic
Posted 06 November 2012 - 09:13 AM
If you head over to droid-life you will see that someone has released a 4.2 gapps for the nexus.
Curious on how easy it would be to convert this for the razr?
Here is a link to it.
Posted 06 November 2012 - 09:34 AM
downloading now.. ill play with it and see if it works
Posted 06 November 2012 - 09:43 AM
I have been using a gapps I found, probably the same one, for a day now and it seems to work pretty good. Can't get Photosphere to work, but the camera still works great otherwise. Gmail and the clock work as well.
Posted 06 November 2012 - 10:42 AM
everything seems to work so far...I like the new camera
Posted 06 November 2012 - 11:52 AM
Gapps 'should' work universally in a compatible OS vesion. As has been discussed previously Photosphere will not work due to a gyroscope not existing/not being active (depending on the source).
Posted 06 November 2012 - 12:52 PM
Here is a link to the gapps that I put up on my host enjoy
flash no wipes
flash no wipes
Posted 06 November 2012 - 02:20 PM
same gapps from droid life or different?Here is a link to the gapps that I put up on my host enjoy
flash no wipes
Posted 06 November 2012 - 02:41 PM
They the same. I mirrored them befotthey disappeared. The zip is huge. Ton of bloat in it
Posted 06 November 2012 - 02:45 PM
K thanks I got the one dloaded from DL quicker so installed on my slot with ft cna and seems to work good!
Posted 24 November 2012 - 02:48 PM
camera fc on koa rom cant use at all i have no camera now can someone please upload a gapps version without the camera? Especially since photosphere doesnt work on our phone anyway, at least some will have the opinion to install without the cam
