Eclipse 1.2 Battery Mod **Depreciated due to 1.2.1 Release**
Link:
Screenshot:
To Flash:
Boot into Safestrap v3.05 (Thanks Hashcode)
Select Eclipse ROM slot (it has been tested and works on other stock based ROMs-{Thanks timmy10shoes and deduct})
Wipe Cache and Dalvik
Install Eclipse1.2_tog_bat.zip
Reboot system
Major Props to Nitro for this awesome ROM. Everything about Eclipse is solid and smooth.
All the code belongs to Nitro and the battery mod came from xda. Thanks to all of them.
Thanks to dubsx too. I have been looking over his themes to see what can be edited.
Note: When using this mod on other stock based ROMs...it will also change your toggles, data, and lockscreen to eclipse.
eye__dea
, Nov 07 2012 06:51 PM
1 reply to this topic
