Screen Calibration?
2 replies to this topic
#1 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 12 November 2012 - 10:03 AM
HI there, I noticed on home launcher, and APEX, the far right side of the screen appears to be the NEXT screen? I have to be real careful where I touch or the screen slides, or the the next screen's program even starts!
Does not happen on the left hand side.
Anyone else see this?
Proud father of a US Marine
#2 SpyderMan
SpyderMan
  • 535 posts
  • LocationBrooklyn, NY
Posted 12 November 2012 - 10:20 AM
newskate9, go into Apex settings, Homescreen settings & be sure that you have the setting to have wallpaper NOT scroll.
If I understood your comments properly; this should fix things for you.
Good luck!
Sig Created by Thach
#3 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 12 November 2012 - 11:07 AM
Spydie (sort of tells you how old I am!),
Thanks for the idea - it happens home launcher too. In fact, I called Verizon (forgive me............) and they wanted me to do a factory reset. I told them I didn't have time right then - so I backed all up, then used the Matt Utility to get back to stock.
Even after reset, stll an issue.
