V6 Supercharger For Bionic Ics
Bionic motorola v6supercharger files
6 replies to this topic
#1 6flip9
6flip9
  • 90 posts
  • Twitter:SIX_FLIP_NINE
  • LocationShelton, WA
Posted 13 November 2012 - 12:02 PM
HOW TO INSTALL V6 SUPERCHARGER ON MOTOROLA BIONIC .246 (STOCK ICS)
PUT TOGETHER THE FILES IN ONE SPOT SO YOU DONT HAVE TO READ EVERY PART OF ZEPPLINROX POST Posted Image
PREREQ:
Posted Image PHONE NEEDS TO BE "ROOTED", IF ITS NOT *GOOGLE HOW*
Posted ImageNEED SAFESTRAP / BOOT STRAP (KNOW HOW TO USE IT/ IF YOU DONT *GOOGLE IT*
Posted Image SCRIPT MANAGER A MUST HAVE FOR THIS, IF YOU DONT KNOW HOW TO USE IT *YOUTUBE IT*
STEP 1 - INSTALL INIT.D (FLASH ZIP)
STEP 2- REPLACE SERVICE JAR (FLASH ZIP)
!!! IF YOU RUNNING A ROM, THEN YOU NEED TO MOD YOUR OWN JAR!!!
PULL SERVICES.JAR FROM SYSTEM\FRAMEWORK AND GO HERE:
STEP 3 - (DOWNLOAD) SCRIPT MANAGER FROM MARKET, YOUR NOW GONNA NEED IT FOR THE REST OF THE WAY Posted Image
STEP 4 -
(*)UNZIP SUPERCHARGER STARTER KIT
(*) OPEN SMANAGER SELECT BROWSE AS ROOT
(*) FIND AND OPEN UNZIPPED SUPERCHARGE KIT
(*) SELECT FILE STARTMEUP.SH
(*) SELECT SU BUTTON, THEN SELECT RUN.
(*) INSTALL EVERYTHING AS SCRIPT RUNS.
STEPS 1-4 ALLOW FOR YOU TO RUN V6 SUPERCHARGER SCRIPT
STEP 5 - SELECT ONE OF THE TWO SUPERCHARGER SCRIPTS (ONE IS IN TESTING THE OTHER IS STABLE)
(*) OPEN SMANAGER
(*) FIND AND OPEN SUPERCHARGER V6 SCRIPT (YES THEY'RE PDF FILES, BUT SMANAGER READS THEM AS SCRIPT)
(*) SCRIPT WILL GUIDE YOU ON WHAT TO INSTALL
IF THIS GUIDE ISNT GOOD ENOUGH FOR YOU, DO LIKE I DID TRIAL AND ERROR Posted Image
:blink: I EVEN NUMBERED THE DOWNLOADS FOR YOU :blink:
THE GOODS >>>>>>>>>>>
<<<<<<<<<<<<< ALL FILES NEEDED TO DO SUPERCHARGE
ZEPPLINROX ORIGINAL POST:
Note: You can use these steps to supercharge any phone.
1. Make sure to pull your own services.jar from system\framework and go here to mod
2. Find your own Init.d flash for your phone via Your Phones Forum (and no thats not a website)
:ph34r:LIKE A NINJA :ph34r:
  • lightsword likes this
i DREAM, iMAGiNE + THiNK BiONiC :-)
#2 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 13 November 2012 - 02:13 PM
Nice work man!
May want to add to set script at boot.
#3 6flip9
6flip9
  • 90 posts
Posted 13 November 2012 - 02:57 PM
I could be wrong but if you have init.d it runs it for you. :)
If you find otherwise let me know
#4 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 13 November 2012 - 04:55 PM
Is the script in your init.d folder?
I personally have never run it this way. I have just ran the script in smanager and set it for boot.
Your method is probably better.
#5 6flip9
6flip9
  • 90 posts
Posted 13 November 2012 - 07:42 PM
YEAH THE INSTALLATION SCRIPT PUTS IT INTO YOUR INIT.D FOLDER AND I BELIEVE IT INTEGRATES INTO YOUR INIT.RC ALSO
#6 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 13 November 2012 - 07:57 PM
Your correct. I just ran it. My method was old...it was when I was on Gingerbread and didn't have init.d support. Sorry about the confusion.
  • 6flip9 likes this
#7 nitephlight
nitephlight
  • 82 posts
Posted 14 November 2012 - 07:10 PM
i long ago thought to create a V6 guide as well- back when ICS leaks were young and people were still mostly ODEX'd. i've had v6 as a staple of my personal tweaking across several devices and it truly measures up every time. so here's my two cents on it:
this will definitely work, but just to clarify, believe all ODEX ROMs (ie stock blur) require manual patching (or Jar Tools script). DEODEXed ROMs can be patched automatically through the V6 script itself.
zeppelin has released as a separate but necessary mod
: it is a Windows script that automates the entire process of pulling, patching and pushing services.jar back onto your phone. this will allow your launcher to achieve 100% supercharge at Die Hard setting. (technically, you can also just bulletproof your launcher within V6, but i've had nothing but trouble down the road doing that)
keep in mind that the higher "looking" settings are not always the best settings (even though they get more turbo sounding in name lol). having high min frees will kill off apps more aggressively than you may have wanted. bulletproofing seems to to be the answer but BPing too many RAM hungry apps defeats the purpose.
last but not least, MAKE SURE you do not have other apps such as Motomizer or ROM Toolbox overriding V6's min free values- and no matter what, DO NOT try to simply wipe V6 folders and init entries manually.. it will eventually lead you to an inevitable system reflash lol
  • 6flip9 likes this
Also tagged with one or more of these keywords: Bionic, motorola v6supercharger files
